Wagon wheels leaking air
Old Aug 9, 2011 | 08:06 AM
DansVette's Avatar
DansVette
Default Wagon wheels leaking air
Seems like I remember this being an issue with some other members.
Anyway, my rear wagon wheels leak air around the bead. Was there a fix for this ?
I've tried fix-a-flat products, and a tire dealer couldn't find a problem with the tires themselves. Nothing works. Any advice ?
Old Aug 9, 2011 | 09:55 AM
bighank's Avatar
bighank
Default On steel wheels I used to sand and then spray paint on the bead area
If no cracks (which I have had on a wagon wheel) try using fine sandpaper around he entire bead area and the spray with clear aerosol paint to make a smoothe surface. Haven't had to try this on aluminium wheels but it sure works for steel wheels that have rust or other imperfections. Also make sure its not leaking at the TPMS. Another place I have found leaks.
Old Aug 9, 2011 | 09:59 AM
mchicia1's Avatar
mchicia1
Could be a crack...that is a telltale sign if the tire is not ripped/has a hole in it.
If you need replacement wheels, I am selling a set in very good condition. Price is negotiable and I am willing to separate wheels (although, only in pairs, not just one)
http://forums.corvetteforum.com/c5-p...condition.html
Old Aug 9, 2011 | 02:43 PM
David426's Avatar
David426
Do you have chromed or painted wheels?? Fix a flat is nasty stuff if you do. It will eat paint or chrome off the inside of the rim where the tire bead makes contact, causing a slow leak.. Learned this from my wifes Lexus with chrome wheels.. What a nightmare that was
Old Aug 9, 2011 | 03:32 PM
Greg00Coupe's Avatar
Greg00Coupe
Are you sure its around the bead? I was fighting a leak and after 8 years my valve stems where leaking. How that occured I have no idea. Just retightened and all is well.
Old Aug 10, 2011 | 03:09 PM
tiojames's Avatar
tiojames
Just snug them up a little. My vert was leaking air and no one could fine the reason. I finally figured out at rest, no leaks, but at speed the centrifugal force from the inside weight of the sensor would allow air to escape.
Old Aug 10, 2011 | 03:26 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
VALVE STEMS! Was thinking the SAME THING!
EARLY SENSOR with O ring installed and back shell NUT. The TORQUE for the nut in in INCH POUNDS so,,, dont over do the torque.
The late model sonsors use an entitely different sensor and seal:
BC
Old Aug 11, 2011 | 02:47 AM
Z16chevelleguy's Avatar
Z16chevelleguy
My 07 convertible had a right rear tire leak that drove tire guys crazy. I have nitrogen in the tires and only when it was below 40 would the tire leak. Two different tire shops tried to fix it over a 3 month period.I told them I had read about seals leaking @ valve stems. But nobody would listen to me. Finally one day I took the car in with a valve stem repair kit and told them to replace it. Hadn't had a leak for almost two years until this winter. Sure enough the seal on the valve stem was torn.
Old Aug 16, 2011 | 04:30 PM
DansVette's Avatar
DansVette
When I spray soapy water around the bead, I can see bubbles in several places.
Guess I'll try the sandpaper method on the inside.
To Wagon wheels leaking air
