Frame cross bar
Old Aug 10, 2011 | 09:35 PM
quik36's Avatar
quik36
Default Frame cross bar
Got a different kind of question. On a 98, there is a part of the frame that runs right behind the seats up high. It is the cross bar that sits up about 4 inches at the very front part of the cargo area. Is that a piece that can be used to mount some equipment? Just needing to drill a few holes for bolts. Is there anything running through that tunnel ?
Thanks for any help, Bill
Old Aug 11, 2011 | 05:17 AM
vettenuts's Avatar
vettenuts
That's an area I have not looked closely at but there is a fuel transfer pipe between the left and right fuel tanks and I wouldn't be surprised if it runs through where you want to drill.
Old Aug 11, 2011 | 07:23 AM
ipuig's Avatar
ipuig
St. Jude Donor '09
Not a good idea, the top of the fuel tanks along with the fuel fill transfer hose are located within the recess created by this cross member.
Old Aug 11, 2011 | 09:16 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Default Frame ****
Here ya go.... An up close and very good view of the bare naked frame:
C6 ZO6 Aluminum Frame:
Some of the pictures detail whats inside that header... Theres a FUEL CROSSOVER TUBE inside that header. BE CAREFUL!! There have been a number of people that have drilled into that crossover. The C6 frame is the same in layout as the C5 frame and the fuel crossover tube is in the same area on a C5.
BC
Old Aug 11, 2011 | 11:40 AM
chaase's Avatar
chaase
St. Jude Donor '12
You can do it, but you have to be very careful of the fuel crossover tube pictured above.
Old Aug 11, 2011 | 01:36 PM
ipuig's Avatar
ipuig
St. Jude Donor '09
Wrong answer, the top of the fuel tanks are located on both sides outboard of the fuel transfer tube.
Old Aug 11, 2011 | 05:28 PM
chaase's Avatar
chaase
St. Jude Donor '12
I know they are. People still mount things there, but you have to be very careful when drilling holes or driving screws.
To Frame cross bar
