Third Brake Light Removal??
Old Aug 17, 2011 | 08:04 AM
Cobrargc's Avatar
Cobrargc
Default Third Brake Light Removal??
My center, third brake light is loose. I tried to access it by removing the carpeted panels inside the trunk, but wasn't able to get to it. How can I get to it?
Old Aug 17, 2011 | 08:24 AM
Silverback99's Avatar
Silverback99
remove the nearest taillight, then you can reach in from there. it's got two nuts holding it in, one on each side.
paul
Old Aug 17, 2011 | 08:48 AM
Bigcountry7's Avatar
Bigcountry7
paul
yup
Old Aug 17, 2011 | 10:31 AM
99 VET's Avatar
99 VET
Oldtimer
St. Jude Donor '13
Agree w/Paul. If your right handed that side & the other side if your left handed. You have to do this by feel. Good luck!
Old Aug 17, 2011 | 11:09 AM
Bill Vett's Avatar
Bill Vett
Do not over tighten. A little loose is better than stripped threads.
Old Aug 17, 2011 | 01:24 PM
DeeGee's Avatar
DeeGee
This is to replace the lamp but answers your question.
Third Brake Light Replacement
Remove one of the tail lamps
You can get to the 3rd brake lamp unit through the tail light opening
Disconnect the electrical connector from the stop lamp
Remove the screws holding the lamp to the rear fascia
Take out the old lamp
Fit the new lamp in the rear fascia housing
Loosely fit the screws
Align the new lamp
Tighten the screws
Reconnect the electrical connector
Reinstall the tail lamp
Old Aug 17, 2011 | 04:35 PM
Cobrargc's Avatar
Cobrargc
PERFECT! I will give it a try tonight.
Old Aug 19, 2011 | 02:15 AM
rick4grafx's Avatar
rick4grafx
I found it easier, with more room for your arms, to go through the back-up light/ license plate surround, it's just 2 more screws to remove, and then the 3rd brake light is directly above. Remember everything is opposite and you are working blind, by feel.
Old Aug 19, 2011 | 02:54 AM
NorCalVette Kid's Avatar
NorCalVette Kid
St. Jude Donor '09
This is how I did it when I changed my 3rd brake light.
Old Feb 14, 2021 | 12:35 AM
Kojowatu's Avatar
Kojowatu
Is this on a C4?
Old Feb 14, 2021 | 10:06 AM
Autoeng's Avatar
Autoeng
Originally Posted by Kojowatu
Is this on a C4?
No, this is a C5 3rd brake light
Old Feb 14, 2021 | 11:46 AM
And this is a 2011 thread.
Plus moving this over to C5 Tech.
To Third Brake Light Removal??
