Vibration over 2500rpms
Old Aug 19, 2011 | 05:35 PM
The Highlander's Avatar
The Highlander
Default Vibration over 1800rpms
Hello Guys,
I'm having an issue here with a c5 z06 with an ls7 installed.
Problem:
It happens no matter what. Clutch in, clutch out. Gear in gear out, moving or stationary.
My guess:
Pilot bearing.
History:
This car came from another shop. The car didn't vibrate the first time I tuned it. Customer installed an RPM transmission, clutch and carbon fiber drive shaft. Afterwards, the vibration started.
Engine had oiling issues so it got pulled.
New engine from LME was installed.
Vibration still. While on the other shop, they turned the car back to stock but with the LME engine. They did change the clutch and everything.
Vibration still.
Any thoughts?
Old Aug 19, 2011 | 05:57 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
Originally Posted by highlanderc
Hello Guys,
Problem:
My guess:
Pilot bearing.
History:
Vibration still.
Any thoughts?
improper balance flywheel.
Old Aug 19, 2011 | 07:13 PM
The Highlander
Flywheel was balanced. Spec 3 clutched.
And the same problem with 2 different flywheels already.
it might be that the flywheel was damaged at the moment of installation.
Old Aug 19, 2011 | 07:49 PM
Evil-Twin's Avatar
Evil-Twin
No there are balance plug holes on the back of the flywheel... the flywheel itself is zero balanced,, but the holes are to balance the rotating assembly of the engine...using the original factory weights will bring the rotating assemby into final balance. you need to know what weights were used in the original flywheel or you need to get the engine balanced.. the flywheel is were the weights are added to zero out the whol rotating mass. Some engines require very little weigh ( like 3 grms. ) but others require more.. its these motors that will vibrate when not properly balanced. also the whole clutch assembly ( flywheel, disk, pressure plate ) need to be match marked at zero balance and assembled the way it was balanced. Then weighs are added to the flywheel to complete the motor balance.
Old Aug 20, 2011 | 01:33 PM
STLSPARKY's Avatar
STLSPARKY
The drive shaft being off center in the torque tube will also cause a slight vibration.
Old Aug 20, 2011 | 02:47 PM
Evil-Twin's Avatar
Evil-Twin
Torque tube is not an issue here because the OP has stated that the vibration is present even with the clutch in ( disengaged )and out of gear.... making this a flywheel, pressure plate, forward issue.
Old Aug 20, 2011 | 05:38 PM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
ET is right on the mark here. With the proper equipment and someone that knows how to use it, this type of imbalance can be corrected with engine in the car. It can take about 1 to 3 hours to complete a good balance. From GM the harmonic balancer can also have added weights to correct the front plain imbalance of the engine.
Old Aug 20, 2011 | 10:10 PM
STLSPARKY's Avatar
STLSPARKY
Yep, my mistake.. I have an A4(in which the torque tube spins no matter what) I had a vibration from mine being off center after putting it back together.
Old Aug 21, 2011 | 02:07 AM
The Highlander
I am using a perfectly balanced engine from late model engines.... this is not a stock engine.
But the problem began with the other engine which was a stock engine. So what is causing is a "carry over" to this engine.
I am still guessing is the pilot bearing. I am looking to see where to start looking for this issue.
Old Aug 21, 2011 | 09:23 AM
Eric D's Avatar
Eric D
Why are you focused on the pilot bearing? What is a "perfectly balanced engine from late model engines". Any engine regardless of where or how well built can have residual imbalance that will cause vibration if not dynamically balanced.
Old Aug 21, 2011 | 10:17 AM
Evil-Twin's Avatar
Evil-Twin
FYI. for your information, Eric and I are both Corvette platform Factory Engineers, while I am retired, Eric is still working. I started on the C5 platform in 1995. Like Eric has said, why are you focused on the pilot bearing? It is a very small concenteric item . You could spin a pilot bearing at at 10,000 rpm and it will still be perfectly balanced.. Again " what is a perfectly balanced engine from Late model engines?
You are asking for help, we are both trying to give you some, but refuse to consider we may actually know something. Something as simple as the pressure plate being out 120 degrees from the flywheel would be a much higher reason for your balance problem. IN most cases pressure plates can attach to flywheel in any of three locations thus the 120 out. Match marks are placed on both the pressure plate and flywheel to have a zero balanced assembly. Then this assembly is connected to the engine. This assembly is also used to adjust the internal rotating assembly. Like adding weights to a wheel and tire balance rotation.
Old Aug 21, 2011 | 02:55 PM
The Highlander
Its not a focus, just a guess!
Point being! We had a perfect stock ls7 and it was ok! This customer installed a clutch/ driveshaft and an rpm trans onto the stock ls7! Vibration started!
Engine got busted and a new engine from lme was installed!
Same vibration
Stock clutch was installed and stock driveshaft! Same vibration
Went to balance the new clutch! Some balancing was done, albeit very little! Same vibration
Just a fyi! This is not a small vibration! This is a huge vibration!
This was done by his previous mechanic and im tasked to find it now!
Old Aug 21, 2011 | 02:58 PM
The Highlander
Im sorry, by no means i am refusing help! Nor do i imply that i know more than anyone here, otherwise i wouldnt have posted!
My guess is that if the pilot bearing was misaligned it could cause this vibration!
Either way i have to open up!
Old Aug 21, 2011 | 03:19 PM
Eric D's Avatar
Eric D
Where is the vibration felt, shifter, seat, steering wheel? Is there an rpm that is worse compare to others or does it continue to increase in amplitude the higher it rev’s? What flywheel is currently installed?
I’m not sure who “lme” is, but have you talked to them about the vibration? Are you using stock or aftermarket engine mounts?
Chances are the vibration has nothing to do with what was in the car before the engine swap, even though it may feel the same. Once the above questions are answered I could better suggest how to fix it.
Old Aug 21, 2011 | 04:06 PM
The Highlander
I need to check that clutch and other stuff too! I really think there is a huge issue with the clutch or pilot bearing!
Old Aug 21, 2011 | 04:08 PM
The Highlander
Vibration is felt in the whole car!!!
A heavy rrrrrrrrrrrrrr vibration! It gets worse with rpms! Comes on at about 1800rpms
Stock mounts!
Old Aug 21, 2011 | 04:10 PM
Eric D's Avatar
Eric D
The only way a pilot bearing could cause the amount of vibration you are describing to have is if it is missing all together. There would be much noise beside the vibration too.
Time to get out the balancing equipment. No need to pull the drivetrain apart.
Good luck!!
To Vibration over 2500rpms
Old Aug 21, 2011 | 04:11 PM
The Highlander
The only way a pilot bearing could cause the amount of vibration you are describing to have is if it is missing all together. There would be many other noise beside the vibration.
Good luck!!
That could be !
I really appreciate your inputs!
Currently it has a spec clutch installed
Old Aug 22, 2011 | 12:57 AM
Smokin Joe's Avatar
Smokin Joe
For my education...could it be an unbalanced drive shaft...or a universal joint? If no, what would indicate a problem in these areas?
If yes, has the OP looked at this. He said there was a new cf drive shaft.
Old Aug 23, 2011 | 11:51 AM
Eric D's Avatar
Eric D
Ok, per your request, for your education, “unbalanced” is typically to reference someone’s state of mind or mental stability. Though this might describe some of us here on the Corvette Forum, I doubt it has anything to do with the driveshaft.
I’m sure or I would like to believe you meant imbalance, which the propshaft could have, however, the OP stated it vibrates with the clutch disengaged. When the clutch is disengaged the propshaft doesn’t rotate with the car stopped. As far as universal joints causing an imbalance, I suppose this has a possibility; however this stock Corvette does not have universal joints, so this also would be a no to a vibration source.
