Vibration over 2500rpms
Old Aug 23, 2011 | 12:15 PM
lucky131969's Avatar
lucky131969
Originally Posted by Eric D
Ok, per your request, for your education, “unbalanced” is typically to reference someone’s state of mind or mental stability. Though this might describe some of us here on the Corvette Forum,
That would be me
Old Sep 2, 2011 | 02:39 PM
The Highlander's Avatar
The Highlander
Updates...
Removed the driveshaft and installed torque tube...
still a vibration!
Old Sep 2, 2011 | 03:28 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
When your engine was originally assembled, it was run on the assembly line and MINOR balance adjustments were made ( if necessary) to the flywheel /flex plate and damper to meet GM SPECS. They add small metal pins to the outside rim of the flywheel and or the damper if necessary to achieve that SPEC BALLANCE.
SO,,,, your OEM damper and OEM Flywheel / flex plate are a part of the balance equation.
When you remove the flywheel or damper, your suppose to MARK the relation to the crank.
IF you install a ZERO balanced flywheel or damper, it may be SIGNIFICANTLY off from the OEM balanced parts that came from GM to make your engine correct.
I JUST installed a SPEC DUEL DISK assy on my 02 ZO6. I took the old fly wheel and the NEW Flywheel to the machine shop and had the machinist balance match the new fly wheel to the old one.
I installed the flywheel on the engine with the drive train disconnected and cranked it up. Ran it up to 6500 rpm’s to check for any abnormal vibrations. There were NONE! THANK GOD! It sure did sound mean open headers!!!!!
Pull the pressure plate off the flywheel and see if the vibration is still there. Maybe its the pressure plate like ET STATED BEING CLOCKED WRONG.
Keep us informed on the status.
Bill
