ls7 camshaft
Old Aug 21, 2011 | 02:57 PM
Fotograf2's Avatar
Fotograf2
Default ls7 camshaft
How well does the LS7 camshaft work in an LS1
I know there are other options but I'd rather have the LS7 camshaft
Because I have one of those already in the garage
Old Aug 21, 2011 | 03:03 PM
Lothar34's Avatar
Lothar34
That cam is designed for big cubes and high-flowing intake and heads. It is really not suited to the LS1/6.
Old Aug 21, 2011 | 03:27 PM
Fotograf2's Avatar
Fotograf2
I will be switching to other heads
Old Aug 21, 2011 | 03:29 PM
BRTC5's Avatar
BRTC5
Pop
Old Aug 21, 2011 | 03:32 PM
AU N EGL's Avatar
AU N EGL
Wont work at all.
talk to your engine builder about a sec design cam for your heads and application.
Old Aug 21, 2011 | 03:59 PM
Lothar34's Avatar
Lothar34
Square-port heads?
Old Aug 21, 2011 | 04:51 PM
Slow Z06's Avatar
Slow Z06
Originally Posted by AU N EGL
Wont work at all.
works just fine. been running it in my LS6 for over 2 years. You have to use an LS2 timing sprocket, front cover, and relocate the cam sensor.
Old Aug 21, 2011 | 05:26 PM
Silnus's Avatar
Silnus
Curious about the behavior of this cam in an LS1/6. Do you have dymo sheets? E.Ts and MPH? Thanks
Old Aug 22, 2011 | 02:28 AM
Slow Z06's Avatar
Slow Z06
Old Aug 22, 2011 | 06:37 AM
baxsom's Avatar
baxsom
This tends to happen a lot here.
use brand X
brand X wont work
i use brand x all the time and it works fine
Old Aug 22, 2011 | 07:42 AM
AU N EGL's Avatar
AU N EGL
use brand X
brand X wont work
What do you want your car to do?
Not just part A or part B but what is the overall goal for your car.
Most engine builders will let ppl know that they over cam their engine.
the dyno chart above could use a little explanation to help ppl understand how those numbers were made
Old Aug 22, 2011 | 08:20 AM
Papas02C5's Avatar
Papas02C5
the dyno chart above could use a little explanation to help ppl understand how those numbers were made[/QUOTE]
Yes an explination would be good....Those are BIG numbers...
Old Aug 22, 2011 | 08:43 AM
ISeeRed's Avatar
ISeeRed
1169 HP???? That obviously isn't simply an LS7 camshaft in an LS6....Did you use big heads with offset rockers? Forced Induction?
I would think that he could find a more tailored cam for his situation. Not knocking that it can be done....but I would think he'd be better off with a more conventional solution. Not to mention that the cam sensor relocation and other mods might take his "economical" solution out as a factor and he could spend the money on a cam that suits his needs better.
Old Aug 22, 2011 | 10:40 AM
mchicia1's Avatar
mchicia1
If you need to change sprockets, covers, and relocate the cam sensor, that is not worth it...you will be already past the cost of a custom grind.
Old Aug 22, 2011 | 12:02 PM
AU N EGL's Avatar
AU N EGL
and this is why I said NO.
far better options then the LS7 cam for a LS6 engine
Old Aug 22, 2011 | 12:42 PM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
There is much more to this than most people think. The LS7 has a different rocker ratio compared to the LS1/LS6. It is also design for higher rpm. Point being, you can't just pull your stock cam and drop in a LS7 cam and expect good results.
Old Aug 22, 2011 | 12:51 PM
Slow Z06's Avatar
Slow Z06
You simply stated that it would not work, I offered a rebuttal that it would work. Although it might not be the right choice for his application. My chart was made on 28psi TT346
Old Aug 22, 2011 | 02:26 PM
Fotograf2's Avatar
Fotograf2
My engine setup
Stroker Kit 383
Mast Motorsports Heads Cathedral Port 11 Degree Small Bore LS1 / LS6 CNC Assembled 215
Mahle Piston
Ls 7 cam
And the cam must be street legal in Sweden and that is the worst thing
etc
Old Aug 22, 2011 | 03:58 PM
AU N EGL's Avatar
AU N EGL
so the cam needs to be a OEM cam ?
street legal has different meanings. What does in mean in Sweden?
To ls7 camshaft
