code problems
Old Aug 23, 2011 | 06:25 PM
shihiran's Avatar
shihiran
Default code problems
hey vett buddies i was on the highway doing like 80mph when my 98 just started to die down on me.so i pulled over and pulled the key to restart it but it was idleing up and down on its own. then i saw my check engine light pop up, so that was when i went into the system and deleted all the codes and it fired right up like normal.any ideas what might cause that because im scared to drive it again and get stuck for sure?
Old Aug 23, 2011 | 06:45 PM
lucky131969's Avatar
lucky131969
Unfortunately, you deleted the evidence with the codes.
Old Sep 21, 2011 | 03:34 PM
shihiran's Avatar
shihiran
pcm P1626 Theft Deterrent Fuel Enable Signal Lost
tcs C1255 EBTCM Internal Malfunction
Old Sep 21, 2011 | 03:36 PM
shihiran's Avatar
shihiran
U1016 Loss of Communications with PCM
Old Sep 21, 2011 | 04:13 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
U1016 Loss of Communications with PCM ,, pcm P1626 Theft Deterrent Fuel Enable Signal Lost
NO FUEL, NO BRAINS = NO POWER
I think that would have something to do with the issue.
Your most likely having a serial data buss issue. It MOST LIKELY being caused by the connectors in the accordion tube between the doors BUT,,,,, thats all speculation on my part. Just for the heck of it,, I would start there and fix the frmale pins in the plugs that are deformed.
Old Sep 21, 2011 | 04:15 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Im having an issue with photo bucket but, heres a post with the info that you need:
http://forums.corvetteforum.com/c5-t...lem-today.html
To code problems
