If you create a number of jumper wires, you can add each system (one at a time) and see if communication is restored.
Ok now if i want to jump out the white (evac) wire how would I go about doing it?
Would i insert a wire into all the other slots except the whit wire and twist them together?
Im a novice at this.
Yes, add systems a wire to each system(and connect the ends together), isolating the ones you don't want, and see if communication resumes.
i had this happen to it was the yellow wire under the pass side footwell dont use it for the mem wire. if that is your problem it would take my car 5 sec to start holding the key all the way down for that long and alot of problems were happening so i used the mem wire on the converter box
I put a wire between the light green and dark green and it didnt start
ran codes with them jumped and got no comm to the pcm. thats wierd isnt it?
.....was communication restored to the BCM? I would have at a minimum: light green, dark green, gray, and purple. Make sure the shorting plug on star connector #2 is pulled.
I connected light green, dark green, gray, and purple still no comm to BCM. I tried it with other combos also leaving the radio and HVAC wire out of the loop. no good on any combo. Is the BCM toast?
I'm not ready to call it dead yet. PM me your email, so I can send you the BCM schematics. You need to check every 12 volt/ground input to the BCM.
I have 12 volts to mini fuse 9 and 12.
When I checked BCM plug C2 pin D12 and D13 at first I didnt get a reading then I got 11.6 volts on one forgot which one then I could not get a reading on either of them. I am getting tired will try again tomorrow after work. thanks
