Suspension
Old Aug 30, 2011 | 01:23 PM
JR01C5's Avatar
JR01C5
Default Suspension
I'm looking to tighten up the suspension on my 118k mile c5. I replaced the the shocks with c6 z51 and it helped a little but it still feels a liilte loose. What else should I change out to help make the car feel tight.
Old Aug 30, 2011 | 01:37 PM
Bluefire's Avatar
Bluefire
Larger sway bars and poly bushings.
Old Aug 30, 2011 | 10:27 PM
jeanlucpicard's Avatar
jeanlucpicard
Get new MOOG end links, ball joints, VBP bow springs -800# front, 600# rear, T1 sway bars with solid aluminum end links. Bolt it all together, get an alignment and hit the track!
Old Sep 2, 2011 | 01:19 PM
JR01C5's Avatar
JR01C5
Thanks for the info! Since I'm on a budget looks like the c6 z06 sway bar's seems like the route to go.
Old Sep 2, 2011 | 02:18 PM
Gideon's_Test's Avatar
Gideon's_Test
From what I read in the past, the C6 Z51 sways were a better choice for a C5, unless you have a whole lot tire in the back... Also, make sure you replace the plastic endlinks (if equipped) with the metal ones.
Old Sep 2, 2011 | 02:33 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
OHHHHHHHHHHHHHH YES!! Those C6 Z bars are B I G!!!!
The C6 Z51 bars a a lot better choice!
You can replace the rubber A arm bushings with some graphite impegenated poly bushings for a WHOLE LOT better feel! Your rubber bushings are probably like silly puddy by now!
Old Sep 6, 2011 | 10:25 PM
JR01C5's Avatar
JR01C5
Thanks for the advice! Saved me from making a mistake, time to look at a-arm bushings.
Old Sep 7, 2011 | 12:57 PM
Redhawg's Avatar
Redhawg
What Bill said. I have C6 Z51 bars and new shocks made the car feel better than new.
To Suspension
