yella terror
Old Sep 8, 2011 | 04:33 PM
vettenuts's Avatar
vettenuts
No, wanted to see how much lift he was running and if he was running the standard spring since valve bounce can occur. Sometimes a failure is a symptom as opposed to the problem itself.
Old Sep 8, 2011 | 04:43 PM
sabastian458's Avatar
sabastian458
Originally Posted by pewtervette01
last April vengeance racing
I have a thread on LS1tech about this. There is contact info for Yella Terra. Also you can contact your supplier and they can assist you in the replacement.
I still have my 2nd set in my LS2 and they are working great. And I bought my 1st set from Vengance also
EDIT- found the thread, I have one on here also. (edit- not my thread, but one where I posted in)
http://www.ls1tech.com/forums/genera...r-failure.html
http://forums.corvetteforum.com/c5-t...a-rockers.html
Old Sep 8, 2011 | 04:47 PM
sabastian458
Originally Posted by bmfrc
Welcome to the club!
That doesnt look like the ones I have.
Old Sep 8, 2011 | 04:57 PM
pmj341's Avatar
pmj341
St. Jude Donor '08-'09-'10
those look like Crane's
Old Sep 8, 2011 | 05:15 PM
mAydAy121's Avatar
mAydAy121
St. Jude Donor '10
Originally Posted by Nate B
I know two people that have had YT rockers break here in the last month, one of them took out his motor. He called yellow terra and they told him they werent designed tor more than 400 lbs of seat pressure...
And we're comparing a solid roller setup to a hydraulic setup......why? If you've got 400# of seat pressure on a hydro setup you're screwed from the get-go. Your average H/C LS will likely be under ~150# on the seat and under ~400# open (some may be a tad more...not much).
Seems like there's been a lot of 'bad batches' of yella terra's. That said, my Jesel's were part of a bad batch and cracked at the tips. The difference is, Jesel told me to send the whole set back and rebodied every one of them for free, no questions asked....
Old Sep 8, 2011 | 05:58 PM
miami993c297's Avatar
miami993c297
What amount of lift are you concern about with the Yella Terra rockers???
On my previous build, the LS6 stock rockers trunion upgraded handled 7400rpm everyday with a 0.630 intake lift for 30000 miles without causing any damage to the valve guides...and without any valve-train instability!!!
That is not theory, but facts.
Christian
Old Sep 8, 2011 | 06:01 PM
vettenuts's Avatar
vettenuts
Not concerned on the lift per se, but the amount of static force being applied to the rocker at full open.
Old Sep 8, 2011 | 06:28 PM
miami993c297
Understood...you are speaking of "static forces" (A Static force is a force that is frictional, and pulls two things together.)
To make that short:
- What kind of camshaft lift vs spring pressure is overrated for the Yella Terra Rocker?
Christian
Old Sep 8, 2011 | 06:59 PM
vettenuts's Avatar
vettenuts
A static force would be a height/stiffness calc. No inertial forces.
There are two questions, is the rocker heavily loaded or conversely, is the rocker not being correctly controlled.
Old Sep 8, 2011 | 07:10 PM
miami993c297
I don't feel this is the place to debate about "static force"...I let it to you
Do you, or the factory, have numbers in term of camshaft lift and spring pressure limitation for the Yella Terra rocker before compromising the aluminum integrity at the weakest spot?
As you ask this specific question in your post # 19 you must have the answer...
Christian
