HELP!! Tapping/Clicking sound from engine (Video)
Old Oct 13, 2011 | 11:52 AM
  #61
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
Originally Posted by adham
Yeah I just assumed it was normal and went with it.
I picked up a custom grind 234/234 .601/.601 114 LSA on EPS lobes spec'd by Patrick G. I got everything installed including the LS7 lifters, new head gaskets and bolts, cam, new oil pump and timing chain. Also went ahead with a new cam retainer plate since the gasket on my old one was flat. Obviously went with all the new gaskets and new bolts to go along. Everything went pretty smoothly. The car runs strong and sounds great!
Glad to hear it all worked out for you. Much better than having to replace the whole engine in regards to the pocketbook!
