converting to LS6 MAF
Old Sep 5, 2011 | 11:20 PM
futuretech's Avatar
futuretech
Default converting to LS6 MAF
I am converting my 2000 to the LS6 MAF. I have the adapter cable. Do I have to disconnect the IAT from the air duct? If so, which one is it and do I just "unplug" it" Will it throw any codes?
Dyno tune to follow next week.
Old Sep 5, 2011 | 11:45 PM
Silverbullet00's Avatar
Silverbullet00
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
Don't be offended by my question,,,,but why do this? You need to do a bit more research,,,,any "gains" will not be much. Leaving things unplugged,,,,
Just sayin/askin,,,,,?
Old Sep 6, 2011 | 02:03 AM
futuretech's Avatar
futuretech
reasonable question. I blew my LS1 this summer and installed an LS6 in its place. Since everything else is converted, and I race the car, I figured I would upgrade everyting to LS6 before my dyno.
Old Sep 6, 2011 | 06:28 AM
baxsom's Avatar
baxsom
doesnt the LS6 MAF have the IAT inbedded in it? You have to splice the current IAT wires to the new MAF plug?
Old Sep 6, 2011 | 08:06 AM
lucky131969's Avatar
lucky131969
To Fred.......If you have the correct adapter harness, then it should plug into the new MAF, and split out .....one for the old MAF, and one for the old IAT. You can just unplug the IAT, and leave the sensor in there, until you change the duct...plug it up....etc. If you have to do any splicing, you have the wrong harness.
Old Sep 6, 2011 | 12:02 PM
futuretech's Avatar
futuretech
Can I just us the existing IAT and just get the adapter 3/5 wire adapter for the MAF? In other words, not use the IAT in the LS6 Maf.
To clarify...Do I need to use the IAT in the LS6 MAF?
Old Sep 6, 2011 | 12:13 PM
lucky131969
I guess you don't, but I don't see the point of buying the adapter harness, and not doing the conversion.
Old Sep 6, 2011 | 01:01 PM
futuretech's Avatar
futuretech
I already bought the harness (without the IAT splice)...during engine rebuild...and then found about the split adapter. So either I use this one or buy the splitter.
Old Sep 6, 2011 | 01:43 PM
lucky131969
Ok, I'm confused. You bought a harness, to adapt a 3 wire MAF setup, to a 5 wire MAF setup......and it does not have provisions for the IAT?
Old Sep 6, 2011 | 01:48 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The new MAF connector should have the wires for the MAF and the IAT. The IAT sensor is built into the LS6 MAF. If you look inside the MAF you can see it. Its a small black bulb that protrudes from the inside the MAF wall.
If it were me,,, I would just CUT OFF the wires on the old IAT and splice them on to the NEW MAF connector. Leave the old IAT in the ducting for a PLUG!
BC
Old Sep 6, 2011 | 03:30 PM
futuretech's Avatar
futuretech
Thanks guys. I just went ahead and ordered the correct cable.
To converting to LS6 MAF
