Bouncing RPMs
Old Sep 6, 2011 | 05:04 PM
vickvette's Avatar
vickvette
Default Bouncing RPMs
This morning I started my car, put it in reverse, got out the parking lot, turned the A/C on and the engine died while in neutral waiting for the garage gate to open. I turn on my engine and it keeps bouncing between 400 - 650 rpm and than it goes up to 800 and stays there. While driving it's okay because I have it in a gear but when stopped at the traffic light it goes all the way down to 400 and than something pulls it up to 700-800. It sounds like the engine's gonna die but something kicks in and helps the engine to get back to 700 but it bounces few times before between 400-600. What might be the problem? It did it few times before never paid to much attention to it but today is the first time the engine died right after I turned it on and turned on the A/C.
Thanks,
vick
Old Sep 6, 2011 | 05:35 PM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
Thanks,
vick
What codes are showing in the DIC?
Old Sep 6, 2011 | 06:44 PM
vickvette's Avatar
vickvette
Well, the DIC is not showing anything. I've never seen any codes there /unless I have to go to a special screen or something/.
Old Sep 6, 2011 | 06:50 PM
_r2h's Avatar
_r2h
1) Turn on the ignition but don't start the engine.
2) Press the "reset" button to turn off any warning messages
3) Press and hold "options" and
4) While holding "options", press "fuel" four times within a 10-Second period.
Old Sep 6, 2011 | 07:23 PM
cdkcorvette7's Avatar
cdkcorvette7
More detailed instructions courtesy of Bill Curlee:
Originally Posted by Bill Curlee
POST DTCS!!!
READING YOUR Engine Diagnostic Trouble Codes (DTC)
This procedure should be carried out any time you experience a problem with your C5. Most inexpensive store bought aftermarket code readers will ONLY read power train DTC’s. Reading the DTC’s with the C5 built in code reader will allow you to read ALL the modules in the vehicle.
The Diagnostic Display Mode is entered with the following procedure:
2) Press the RESET button to turn off any warning messages. (i.e. door open, trunk open ect)
3) Press and hold the OPTIONS button
4) While holding OPTIONS, press FUEL button four times within a 10 -second period.
Initially, the on-board diagnostics go into an Automatic Mode which will cycle through each module and shows diagnostic codes in a pre-set sequence: PCM - TCS - RTD - BCM - IPC - RADIO - HVAC - LDCM - RDCM - SCM - RFA. All codes will be displayed for each module. ( i.e. PCM = 4 codes) If none are present in a given module, you will see No More Codes on the display.
There are two types of diagnostic codes, Current and History designated with a letter suffix, “C” or “H”. A current code indicates a malfunction is present in the module displaying data. A history code indicates a problem existed sometime in the last 40 or 50 ignition cycles. When not accompanied by a current code of the same number, it's potential evidence of a previous problem, now resolved, that was not removed by clearing the codes. More likely it's an indication of an intermittent malfunction.
Intermittent codes are the most challenging of the diagnostics. An intermittent code may have happened once, may have happened more than once but is inconsistent or may be happening on a regular basis but not at the time the codes are displayed. History codes can also be caused by a current malfunction in a system that is not operating at the time codes are displayed. An example is the rear window defogger which doesn't operate until the Body Control Module detects engine rpm. For history codes set by a module that does not operate with the key on and engine off, a special diagnostic tool called a Scan Tester is necessary to properly diagnose the malfunction.
Once the system has displayed all modules, it goes into the manual mode which allows selection of each module using combinations of Driver Information Center buttons. Manual mode can also be entered during the automatic sequence by pressing any button except E/M. Once the display shows Manual Diagnostics, select a module by pressing the OPTIONS button to go forward or the TRIP button to go back. Once a module is selected, a code is displayed, and if more than one are present; press GAGES to go forward or FUEL to go back.
To exit the diagnostic mode at any time, press E/M. If you want to erase codes in a given module, press RESET To reset the codes once in manual mode, press and hold RESET until it displays NO CODES Press OPTIONS to go to the next module. Repeat the steps until you have reset the codes in all the computer modules.
NOTE!! Only reset the codes IF you want to - it is NOT necessary to do this. Clearing a code does not repair a problem. You are simply erasing the evidence of it in the module's memory. If you clear the code/s, and extinguish the Check Engine Light, your emissions status ready will NOT allow you to pass an emissions test until you have completed the required driving cycles. There are a few body module DTC’s that if set will prevent the module from operating properly. Once the DTC is cleared, the module will return to full function. This is not true for power train DTCs.
If you have never read and cleared your codes, there will probably be a lot of old history DTCs. It is recommended that you clear your codes and see if any come back during a driving cycle. Those are the ones that you need to concentrate on diagnosing.
Once you have the codes, the next question is: What to do with the information?
First, consult the factory service manual. Any serious C5 Do-It-Yourself owner should invest in the Corvette Service Manual of the appropriate model year. The Service Manual is really a requirement if you want to understand and work on your C5.
NOTE and a WARNING. You can read the DTCs while the engine is running. I pull mine up all the time while driving.
WARNING. Don’t become distracted while reading DTCs while your driving and cause an accident!!!!! Use common sense and drive safe.
These are some very good C5 Diagnostic Trouble Code (DTC) explanation web sites!!! They also explain how to read the DTCs
Here are some very good sites that explain what DTC mean:
http://www.gearchatter.com/viewtopic11755.php
http://www.obd-codes.com/trouble_cod...d-ii-codes.php
Make sure to include the H or C suffix when you post your DTCs!!
Old Sep 6, 2011 | 07:40 PM
vickvette's Avatar
vickvette
Thanks,
I got few codes here:
38RTD - U1000H
AO-LDCM - B2282H B2284H U1064H
AO-RDCM - B2283H B2285H U1064H
A6-SCM - B2607H
Old Sep 6, 2011 | 10:43 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Check for an air leak in the air ducting between the MAF & Throttle Body and also check ALL the vacuum lines for damage deteroration. Sounds a LOT like a vacuum leak...
BC
Old Sep 6, 2011 | 11:20 PM
Evil-Twin's Avatar
Evil-Twin
St. Jude Donor '03-'04
BC
From one Bill to another, I concur, a classic sign of a vacuum leak.
Bill aka ET
Old Sep 6, 2011 | 11:26 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Bill aka ET
Hea Bill
Seen those symptoms TOO many times!
BC
Old Sep 6, 2011 | 11:34 PM
Evil-Twin's Avatar
Evil-Twin
Hea Bill
BC
I usually see those vacuum leak situations after I have a beer and Burrito lunch...
Old Sep 6, 2011 | 11:49 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I thought that would be a case of F/I and a BLOW OFF VALVE operating correctly!
F/I (FOOD INDUCTION)
Old Sep 7, 2011 | 12:07 AM
vickvette's Avatar
vickvette
Thank you guys, I'll look at it tomorrow and let u know :-)
Old Sep 8, 2011 | 03:46 AM
vickvette's Avatar
vickvette
Yes, it was a small hose that was hard as rock. Instead of getting a new one from the dealer I just hooked up one with two clamps on each side and works just fine :-)
Thanks guys,
vick
To Bouncing RPMs
