Annoying Rattle UGGGHHHHH w/ Video
Old Sep 6, 2011 | 06:47 PM
SpeedyRCM_TX's Avatar
SpeedyRCM_TX
Default Annoying Rattle UGGGHHHHH w/ Video
Almighty Corvette Forum, I need some help trouble shooting a crazy annoying rattle coming from my 02 Z (cam, exhaust and RPM Level 5 tranny)
It started about 2 weeks ago, but doesn't seem to have affected anything driving related. The car idles, accelerates and decelerates just fine. I can only hear the rattle at idle, but it may be because it isn't loud enough to overcome the exhaust, cam or road noise.
I got it up on jack stands over the weekend and checked all the connections and fittings and what not and everything is tight. The rattle definitely comes and goes, but it is present more often than not. It also doesn't change if I have the clutch engaged or disengaged or in gear or neutral.
Any ideas???
You can hear it in both the video clips. The first one, you can hear it, then stop, then start back up.
Please help!
Old Sep 6, 2011 | 07:04 PM
bumble-z's Avatar
bumble-z
I couldn't get the audio.
Check for a broken weld at the clip/clips that attaches from the header at the bell housing.
Old Sep 6, 2011 | 07:21 PM
lucky131969's Avatar
lucky131969
Did you have the engine running while up on jackstands?
Old Sep 6, 2011 | 07:27 PM
SpeedyRCM_TX
I did start it up while it was on jack stands.
Old Sep 6, 2011 | 07:31 PM
Zeus-of-Boost's Avatar
Zeus-of-Boost
dude i feel ya, i had a 98 ws6 that did something like that. i adventually put the car up in the air and had my wife rev it up to the certain RPM to make it rattle. it was a damn exhaust hanger.
my advice, jack the car back up and let someone crank the car and slowly rev it up until the rattle comes back. then get under the car and find that sucker. be very carful under a running car and make sure you a STURDY lift system
Old Sep 6, 2011 | 07:39 PM
oh1vette's Avatar
oh1vette
be very carful under a running car and make sure you a STURDY lift system[/QUOTE]
Words to LIVE by
Old Sep 7, 2011 | 02:51 PM
SpeedyRCM_TX
When I pulled into the parking lot at work this morning, the rattle was in full force. I left the car running and went to the back and put my foot on the tailpipes and applied pressure in mutliuple directions to see if it would effect the rattle and couldn't tell any difference. Didn't change the frequency, volume or anything so I'm having a hard time convincing myself it is an exhaust issue.
Old Sep 7, 2011 | 02:55 PM
mojo1's Avatar
mojo1
St. Jude Donor '06 thru '15, '19
get cut outs, the rattle will not be heard. Just saying, good luck with it I know it will drive you nutts!
Old Sep 7, 2011 | 05:22 PM
Chicago1's Avatar
Chicago1
I don't hear anything thing metal with a "ting" pitched sound but at work so can't listen to it that high. I would agree about jacking it up and starting it and revving and see what you find. BE CAREFULL!!!!
Old Sep 8, 2011 | 05:51 PM
ipuig's Avatar
ipuig
St. Jude Donor '09
What type of clutch do you have?
Old Sep 8, 2011 | 06:43 PM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
could be part of the cats rattling around.
Take it to an exhaust shop and disconnect your exhaust
Old Sep 9, 2011 | 11:34 AM
SpeedyRCM_TX
Stock clutch.
Old Sep 9, 2011 | 11:37 AM
SpeedyRCM_TX
I thought the same thing this morning. When I started it up today, it was rattling worse then it ever has before, then as I started driving it stopped. Didn't rattle at all on my way to work this morning, but the exhaust note sounded different. I couldn't quite figure out how it was different, but it definitely was. The exhaust sound was alot deeper and not real crisp like it usually is. (I have Borla Stingers)
I think I'm gonna try to swing it by EnglandGreen's today.
Old Sep 9, 2011 | 05:06 PM
EG@EnglandGreen's Avatar
0EG@EnglandGreen
Supporting Tuner
From: ================== Houston, Texas www.englandgreen.com ================== Necessary Evil™ __________
CI 6-7-8-9-10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Problem solved
Old Sep 9, 2011 | 07:08 PM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
Originally Posted by EG@EnglandGreen
Problem solved
what was the mystery?
Old Sep 9, 2011 | 11:22 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Inquiring mind would like to know what it was
Old Sep 10, 2011 | 08:06 AM
mojo1's Avatar
mojo1
Problem solved
spit it out!!!!!!!!!!!!
To Annoying Rattle UGGGHHHHH w/ Video
Old Sep 10, 2011 | 11:40 AM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
Yep, would like to know what was found. Sounds like a loose bolt in the torque tube or in the front bell housing.
Old Sep 10, 2011 | 01:05 PM
0EG@EnglandGreen
Supporting Tuner
Nothing so dramatic. The entire guts of his passenger side aftermarket catalytic converter was lodged in his 3inch mid pipe just before the over axle - and it was intact
He'll post a pic when he gets a chance.
Old Sep 10, 2011 | 01:36 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Excellent! Good work!
BC
