lifter noise
Old Sep 6, 2011 | 08:28 PM
safeandsound's Avatar
safeandsound
Default lifter noise
put in a new cam and springs and 7.4 pushrods motor is ticking loud,also i have dropped the compresion a little with cometic gaskets .40 i think,could this be the problem..
Old Sep 6, 2011 | 08:42 PM
vettenuts's Avatar
vettenuts
Gaskets shouldn't be the issue. Lifter preload may, what did you set it at?
Old Sep 6, 2011 | 08:58 PM
safeandsound
didn't do a preload just installed everything new and went to 26fp i believe and thanks for getting back so soon,dont now if i will be able to sleep tonight,also to give you heads up new injecktors 60# and new exhaughst,and d1 procharger,
Old Sep 6, 2011 | 09:24 PM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
Well you now know where you need to look first.
Old Sep 6, 2011 | 09:29 PM
vettenuts's Avatar
vettenuts
Also check for exhaust leaks, they can sometimes sound like a lifter noise.
Old Sep 6, 2011 | 09:43 PM
safeandsound
not an exhaust leak for sure its all brand new,and the pushrods are not adjustable car has car ran for only 2min and the moror has not ran in 8 months do you think the lifters need to pump up..
Old Sep 6, 2011 | 10:07 PM
Lothar34's Avatar
Lothar34
Are you using the stock rockers? Did you measure before you decided on 7.400" pushrods?
Old Sep 7, 2011 | 06:26 AM
baxsom's Avatar
baxsom
What cam? 7.4 from what I have read here is the #1 size pushrod for aftermarket cams. You say you only ran it for 2 mins? I would think that it would take longer to pump up the cam. Did you tighten the rockers with the lifters on the base of the cam?
Old Sep 7, 2011 | 08:13 AM
sfc rick's Avatar
sfc rick
Believe it or not, I had a spark plug that wasn't tight enough and it would sounded exactly like a failed lifter. I just had the car in the shop to R&R the plugs a couple of weeks before. But when I heard the ticking I decided to add a cam and other stuff. That's when I found the loose spark plug and laughed at myself for freaking out and buying all the new upgrades.
Old Sep 7, 2011 | 09:26 AM
mchicia1's Avatar
mchicia1
You need to measure pushrod length...you can't just throw in a random size and hope it works. Also the torque spec is 22 ft/lbs not 26.
Old Sep 8, 2011 | 04:01 AM
TXGS507's Avatar
TXGS507
I just did H/C/I install and threw in the LS7 lifters for "good measure"... Most guys upgrade all of that stuff when doing those mods..to me... just seems like good ins.
GL
Old Sep 8, 2011 | 08:40 AM
chevy406's Avatar
chevy406
.. i have dropped the compresion a little with cometic gaskets .40 i think..
Actually you have increased the compression by using a thinner head gasket.
What size cam - or more importantly what lobe design did you install? An aggressive ramp rate is going to result in increased valvetrain noise. But the fact you didn't measure for proper pushrod length or check your rocker arm contact pattern leaves you wide open to not knowing if your geometry is correct. Do some searching on Vettenuts' posts regarding valvetrain geometry. He has already done the work for us to know how to properly measure and setup a valvetrain.
Old Sep 8, 2011 | 09:26 PM
safeandsound
Default fixed
hey boxsom you got it the lifters had to pump up and for everybody else thanks for the replys,great to have this site 20 heads are better than one...
To lifter noise
