I know tune up has probably taken a new meaning. After six years of driving this car, I'm wanting too replace plugs and wires along with the fuel filter. I bought w 40800 miles, and know has 69600 trouble free miles. My problem is I think it's all original, should I expect trouble? Chime in, and thank you. I will take all sugguestion's on types and brands.
If you want an OEM fuel filter get it from Gene Culley at GM Parts House. I got mine off Amazon and have had no issues. You'll want to get a fuel line quick disconnect tool for this...
I don't think you should have too much trouble. Plan on breaking every single original plug wire when you remove them as they get very brittle. Cylinder 7 is a little tough to get at but a little patience and it'll work out.
Based on your avatar it looks like you have a 97, 98, or 99. You might also consider replacing your 10+ year-old transmission, differential and clutch (if it's a 6mt) fluid (for bleeding the clutch fluid search on here for Ranger Method unless you have a remote bleeder line off the slave installed). Take a look at your brake fluid while you're in there. If you're going to bleed your brakes get a motive power bleeder for about $60... Worth it's weight in gold.
Thank you cdkcorvette7, and Bill Curlee. Yes it is a 98 now with C-6 painted wheels. I do know about the wires breaking when disconnecting. broke many of them back in the 70's GTO muscle cars. Work for chevrolet here in Kissimmee i will have one of the tech check diff, do the A-4 and drain and bleed.As for the plugs I'm up for doing that. Again thank you.
the diff fluid is actually very easy on these cars you might want to have a look at it if you can do an oil change you can change the rear end fluid on the c5.
I saw you work for Chevy dealership. Makes sense to just have one of your techs do the work for you. Instead of stock wires, which have a problem breaking when removed (ask me how I know that), consider Taylor wires. I put them on my '04 Z06, and they are great. And no more issues of breaking wires when they need to be removed.
Plus, if you don't have a good service history on the car, change all the fluids -- tranny, diff, coolant, brake fluid -- in addition to doing a normal oil and filter. Can't hurt, and might help.
Oh, and one neglected item -- the clutch reservoir. Lots of people who street their cars never look at the clutch fluid reservoir. It's probably like chocolate syrup by now if you never changed it. At the very least, have them suck the fluid out of the reservoir and put in fresh. Better still is to have the clutch bled. It is the most forgotten part of these cars among people who don't drive them on the track.
I went the GMPP wires and Delco Irridiums route. The engine idles smoother and the performance is back to where it supposed to be. #7 plug will leave you with some battle scars!
You just interpreted it wrong!!! Its called C5 BONDING!
Well done my friend!
