current code p0803 skip shift
Old Sep 13, 2011 | 03:31 PM
vettedarla's Avatar
vettedarla
Default current code p0803 skip shift
i thank you in advance for any suggetions My check engine came on and i discovered a p0803 code 1-4 upshift any suggestions getting
rid of the check engine light
Old Sep 13, 2011 | 03:32 PM
dougbfresh's Avatar
dougbfresh
Do you have a skip shift eliminator installed?
Old Sep 13, 2011 | 04:29 PM
vettedarla's Avatar
vettedarla
Not that I know of, I am the second owner, thanks for your quick reply
Old Sep 13, 2011 | 04:34 PM
dougbfresh's Avatar
dougbfresh
Were you always forced to do the 1-4 shift at low speed or did the light just come on and you could shift anyway you liked? Your problem usually happens when the cheap resistor in the skip shift eliminator fries. I got a larger wattage from Radio Shack and soldered it in to fix the same code.
Old Sep 13, 2011 | 04:37 PM
vettedarla's Avatar
vettedarla
yes i was always forced to shift at low speeds wasn't looking at the
dash board and shifted into second i have had the check engine light
on ever since I would love to know what GM engineers were thinking, thanks.
Old Sep 13, 2011 | 04:42 PM
dougbfresh's Avatar
dougbfresh
It's in the OWNERS MANUAL-it was for gas mileage and avoidance of the gas guzzler tax. On the drivers side of the trans is a plug for the shift solenoid, it the bypass is installed, it will be UNPLUGGED and what looks like a blank will be in the trans and one on the pigtail-the one on the pigtail is the resistor I was talking about.
Old Sep 13, 2011 | 04:46 PM
vettedarla's Avatar
vettedarla
Thank you very much very helpful
To current code p0803 skip shift
