Knock sensor wont come out!! Help!!!!
Old Sep 15, 2011 | 04:18 PM
Speedway1's Avatar
Speedway1
Default Knock sensor wont come out!! Help!!!!
OK, Well I was going to replace both knock sensors on my 01 Z06 because I had a code that said the front sensor was bad. Rear sensor comes right out! The front one will not turn the entire sensor. ITs turning the center part but not the outside which I assume it should all turn. How in the hell do I get this sensor out??? ANYONE EVER seen this before?? Appreciate ANY pointers on this one guys.
Old Sep 15, 2011 | 04:29 PM
cdkcorvette7's Avatar
cdkcorvette7
If you're talking about the connector on top of the sensor you don't turn it to get it off, you pinch the tabs on the sides of the sensor and pull... Use very firm pressure with your fingers or gentle pressure with long needle nose pliers...
Last edited by cdkcorvette7; Sep 15, 2011 at 04:48 PM. Reason: Fixed info... Thanks lucky
Old Sep 15, 2011 | 04:37 PM
lucky131969's Avatar
lucky131969
Originally Posted by cdkcorvette7
You don't turn it to get it out, you pinch the tabs on the sides of the sensor and pull... Use very firm pressure with your fingers or gentle pressure with long needle nose pliers...
I disagree. The knock sensor screws in, and has a torque requirement of 11 lb ft.
Old Sep 15, 2011 | 04:44 PM
dougbfresh's Avatar
dougbfresh
That engire center section comes out, I removed mine to replace the plastic wells at the bottom while I had it open.
Old Sep 15, 2011 | 04:47 PM
cdkcorvette7
Well... this might be twice I've screwed up today.
OP are you talking about the knock sensor itself or the elecrical connector at the top of it?
Old Sep 15, 2011 | 05:18 PM
Speedway1's Avatar
Speedway1
NO,I have the connector off. Its the center of the sensor itself thats turning but not turning the bottom bolt on the sensor. Thanks for the reply anyhow. I just hope im not the ONLY person this has happened to. Im sure there is a way to get it out but if someone has done it would save LOTS of time.
Old Sep 15, 2011 | 08:09 PM
Speedway1's Avatar
Speedway1
Are you talkinng about the valley cover? Center section as in what. IM open for anything here to help get this sensor loose.
Old Sep 15, 2011 | 08:53 PM
Speedway1's Avatar
Speedway1
OK I think your talking about the valley cover that has the bolts in it. From the photos I saw the Sensor has to be removed to get the cover off. So that will not help me in this case. IM going to have to figure a way to unscrew the sensor. Maybe someone has seen this problem before and will give me some pointers.
Old Sep 15, 2011 | 09:53 PM
cdkcorvette7
I didn't take the valley cover off when I replaced my sensors... They just unscrew with a 22mm socket. So if the head of the bolt is turning with the wrench (and it's not broken) then it has to be coming loose... Just unscrew it then reach in there (or grab it with some pliers if you can't get your fingers in there) and pull it out. There shouldn't be any resistance.
I can't remember offhand if the larger center section turned with the bolt head or not. Look at your replacement part and see if they are attached or not...
Old Sep 15, 2011 | 10:32 PM
Speedway1's Avatar
Speedway1
I have one sensor out already. THE front one does not loosen when turned with a soket. The inside part of the sensor turns the rim or outside does not turn. Does this mean the bolt is twisted off? IF so How the hell does one get it out then. I did not twist it off. Must have been that way before. As soon as I tried to loosen it it would not turn the entire sensor only the iside part. Any ideas? Thanks for the photos.
Old Sep 15, 2011 | 10:43 PM
cdkcorvette7
Just so I'm clear... In the image below you're saying that the piece with the blue arrow pointing to it is turning and the piece with the red arrow pointing to it is not right?
Are you sure the hex head on the bolt isn't stripped and is actually turning? Have you looked at your replacement sensor to see if those pieces are attached to each other or are separate and able to rotate independently?
Old Sep 15, 2011 | 11:06 PM
Dixiecrat's Avatar
Dixiecrat
Educate me, what is a knock sensor ?
Old Sep 15, 2011 | 11:23 PM
lucky131969
http://www.engineblox.com/?p=65
Old Sep 15, 2011 | 11:35 PM
cdkcorvette7
As I understand it a knock sensor is just a microphone of sorts. It "listens" for engine knock (detonation inside the combustion chambers). If the sensor detects knock it sends a signal to the pcm which will retard the timing until the sensor doesn't "hear" it anymore.
cdkcorvette7
Cool link
Old Sep 15, 2011 | 11:44 PM
Dixiecrat's Avatar
Dixiecrat
Thanks Lucky.
Old Sep 15, 2011 | 11:56 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
You may have found out why the front one was bad.
That means that you may have to dissect it to get it out. Get your drill out and start dismantling it to get to a part that will allow the main body below the center section to turn.
Bill
To Knock sensor wont come out!! Help!!!!
Old Sep 16, 2011 | 06:36 AM
Speedway1's Avatar
Speedway1
Bill
I see no other way to go at it Bill. Will update if I make any progress. Thanks
Old Sep 16, 2011 | 06:53 AM
Speedway1's Avatar
Speedway1
You are correct! YES
Old Sep 16, 2011 | 09:09 AM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
At this point, you might as well remove the lifter valley cover to see, from underneath, if the threads are stripped and just turning.
You may end up having to drill the sensor out, and then repair the damaged valley cover threads with a Helicoil.
