LS3 or LS7
Old Sep 20, 2011 | 10:43 AM
David426's Avatar
David426
Originally Posted by lucky131969
Who knows.... the point is, you are regurgitating a fear discussed some 5 years ago......and has long since been proven wrong. Next time you see a guy with a c6 Zo6 supercharged, ask him how disappointed he is with 630 RWHP on a conservative tune.....
Dude.. You are living in a fantasy world.. Alex and Toque are correct A boosted LS7 is scary.. A Ticking time bomb.. GM Engineers knew a boosted LS7 was out of the question, when they started the drawing board for the new ZR1..
Old Sep 20, 2011 | 10:52 AM
lucky131969's Avatar
lucky131969
Man, you are right. All the shops have stopped selling the kits, and all the shops have stopped installing superchargers on C6Z06's. They are blowing up left and right...............just my fantasy I guess.
Vortech and Procharger.....take note ! LS7's are blowing up ........stop making compatible SC's immediately !
Old Sep 20, 2011 | 10:53 AM
TexasRob's Avatar
TexasRob
I've been researching some of the advise from the replies. What I've found so far is the ls3 is a very strong block but also read they have oiling issues on road courses. I think I'll be better off going back with 383 stroker ls6 for now.
Thanks for the help!
Old Sep 20, 2011 | 10:56 AM
lucky131969
.....and do you think the LS1/LS6 was designed for boost?
Old Sep 20, 2011 | 01:33 PM
Dominic Toretto's Avatar
Dominic Toretto
You can build a supercharger kit for ANY car and sell it. Doesn't mean the engine was designed for boost applications from the get-go.
-Alex
Old Sep 20, 2011 | 01:40 PM
Dominic Toretto
FYI, LS7s also have some oiling issues on road courses once the car has had upgraded suspension. The factory oiling system wasn't designed for increase lateral acceleration from what I have read here from C6Z owners. Search around the C6Z section and you will see what I am talking about. BTW I love the forged 383 option. Good luck
-Alex
Old Sep 20, 2011 | 05:04 PM
Blue Angel's Avatar
Blue Angel
I hope someone corrects me if I'm wrong regarding the LS3 (in case there's an LS3-specific issue I haven't heard of), but oiling issues on road courses have nothing to do with the engine block. It has to do with oil pan and pickup design, oil capacity, and other factors.
What's happening when cornering is oil gets into the outboard side cylinder head and doesn't drain back down to the oil pan until the car comes out of the corner (no more G's holding the oil up). If the corner is long enough the oil pan can go dry as the pump has put all of the engine's oil into service but none of it is returning to the pan.
As far as I know this happens on all LS engines. The dry sump system introduced on the LS7 was supposed to help with this, but I guess there are still issues?
Old Sep 20, 2011 | 07:40 PM
cantrelmitl's Avatar
cantrelmitl
St. Jude Donor '10
Take a look at the C5 w/ the LS7 that Vengeance just posted and you be the judge. BTW, it drives just like Grandpa Ron shows, can raise H3!! on demand, and will have no problem with a future 100 shot. Yep, I love it. Hhmmmm . . . LS7 and the cubes was my choice. Look up Tim Lynch and I think you will see that an LS7 can hold up to about anything you throw at it. Thanks Ron, Mike, and Charlie!
Mike C
Old Sep 20, 2011 | 09:33 PM
David426's Avatar
David426
-Alex
Yep, If GM could have done a boosted motor with an L/S7, they would have done it in a heartbeat. Durability is the issue. LS1/and LS6 engines take forced induction fairly well, as compared to an LS7.. LS2 and LS3 are prefered overall by many builders. You can melt any motor with Forced induction.. The LS7 with very high compression and thinner cylinder walls is just an accident waiting to happen.. Maybe with a conservative tune and low boost (5-6psi) it might be ok for a long time.. Maybe is the key word. Thin is a bad word
Old Sep 21, 2011 | 06:35 PM
LSOHOLIC's Avatar
LSOHOLIC
FWIW...Pratt and Miller offers a LS7 with a LS9 top end...meaning a "GM" LS7 short block (stock) except they change the pistons to Diamond, teflon coated, forged aluminum, ceramic topped and dished top with an FI ring package (from 11.6 to 9.1). But aside from the piston change all rotating assembly is stock.
Then they bolt on the LS9 cylinder heads and the factory Eaton blower. Upgraded injectors to 65lb'ers and spin it to the factory 10 psi (same as the ZR1).
Are you ready......drum roll.....760 HP and 830lb-ft on pump gas.
And my final thought is if Pratt and Miller is willing to build it and stand behind it then its good enough for me.
Thanks.....and for the love of God..please don't ask who P & M is !!
Old Sep 21, 2011 | 07:05 PM
1999_TRC's Avatar
1999_TRC
So to be clear. It is your belief, that GM made the LS1 and LS6 engines more durable than the LS7, with LS2 and LS3 engines being "preferred". So for whatever reason, GM completely failed with the durability of the LS7, using no lessens learned from the previous LS engines, but finally recovered with the LS9.
Old Sep 21, 2011 | 10:11 PM
LSOHOLIC's Avatar
LSOHOLIC
For those interested in specs....they refer to it as a C6RS. Which is avaliable with a supercharged 7.0 (Brian Thomson built who by the way owns Thomson Automotive and does lots of development work on engine blocks for GM) or the Katech N/A 500ci monster.
Thanks...
Old Sep 22, 2011 | 09:24 AM
  #33
Dominic Toretto
So to be clear. For forced induction applications, is it safer for the block to go with thinner or thicker cylinder walls?
-Alex
Old Sep 23, 2011 | 11:58 AM
  #34
TexasRob's Avatar
TexasRob
Finally got to break down engine. Found two cracks in block on #7 cylinder and the sleeve was pushed up slightly out of the block. I originally started this thread to see about the better ls series block for durability. Looking for 500+hp, NA. I car nothing about adding FI to build. I'm still leaning to a forged ls6 383 but having second thoughts after finding issue with block.
Any thoughts/comments?
Old Sep 23, 2011 | 12:06 PM
  #35
Dominic Toretto
What exactly was the cause of the previous failure? I know you stated there was a crack in the wall and chunk from a piston missing but I don't see where you stated what exactly caused that. Bad tune?
-Alex
Old Sep 23, 2011 | 12:11 PM
  #36
TexasRob's Avatar
TexasRob
Wished I new. My first guess is bad tune or 2nd maybe the stock pistons could not hold up to the mods, 550hp at crank. I bought the car with mods. Car came from Ft. Meyers FL. I do not know who performed the work. I do plan to have LG Motorsports to dyno tune after new build. Also, mods include 42 lb injectors, forgot to add.
Old Sep 23, 2011 | 12:12 PM
  #37
1999_TRC's Avatar
1999_TRC
-Alex
You tell me. Why do all the vendors sell FI kits for LS7s? Why are reputable shops installing the kits on LS7s? Where are the horror stories?
To LS3 or LS7
Old Sep 23, 2011 | 12:14 PM
  #38
1999_TRC's Avatar
1999_TRC
-Alex
Based on your response, it sounds like you are not familiar with #7 cylinder failures. Do some searching, the topic goes back many years.
Old Sep 23, 2011 | 12:25 PM
  #39
Dominic Toretto
Because you can sell parts won't break a car.
Are these same shops telling customer they can safely run as much boost as an LS3?
Why are you not answering the question directly?
Seriously I mean if you have a good point to make just share it instead of beating around the bush. We are here to learn not guess. Well the rest of us are.
-Alex
Old Sep 23, 2011 | 12:38 PM
  #40
1999_TRC's Avatar
1999_TRC
-Alex
You are here to learn, huh? On an internet forum? If a professional opinion is what you desire, then why don't you do yourself a favor, and pick up the phone. Talk to the experts at A&A, LG, England Green, ECS, etc. That does not mean post within this forum, and make a shout out for them to reply. It means you actually and actively pursue the knowledge you desire. Are you willing to do that, or would you rather just repeat what you think is true, from this forum, LS1Tech, etc?
