valve spring questions
Old Sep 22, 2011 | 09:23 PM
VETTEGUY1977's Avatar
VETTEGUY1977
Default valve spring questions
I have a 2000 frc. I am getting my winter mod parts collected. Currently I have a vararam and SLP Powerflo exhaust installed. I have LTs and orx, ls6 intake, and 243 heads that will receive mild massaging. I plan on using an ls2 timing set and a ported ls6 oil pump and probably an underdrive crank pulley.
The cam I have chosen is an EPS 222/226 113 lsa with lift in the high .590's.
My question is will comp cans 918 valve springs be sufficient or are double wound springs be necessary?
I don't tend to rev super high and this vehicle will be used for street use. I doubt it will ever see a track but I tend to drive "spirited" very occasionally.
Also should the cam be a 1 or 3 bolt configuration?
I will appreciate any advice.
Thanks!
Old Sep 23, 2011 | 01:15 AM
Last C5's Avatar
Last C5
I'd be looking at some PAC 1218s or 1518s beehive springs.
Old Sep 23, 2011 | 01:47 AM
C5Natie's Avatar
C5Natie
I wouldnt run any wimpy single springs. I use Manley Nextek springs. They are a double spring. Ive always seen valvefloat at upper rpms on cars with aggressive cams and single springs.
Old Sep 23, 2011 | 10:34 AM
kp1's Avatar
kp1
Lots of people run the single beehive springs w/o issue. I prefer the redundancy of the dual springs and that's what I install on my engines. Break a spring with the duals and you can survive. Break a single spring and you're probably screwed.
Old Sep 23, 2011 | 01:41 PM
VETTEGUY1977
Thanks for the advice! I will go with the double wound springs.
Old Sep 23, 2011 | 11:34 PM
C5Natie's Avatar
C5Natie
Yup, its happened to me. That inner spring can really save your butt
Old Sep 24, 2011 | 07:25 AM
sfc rick's Avatar
sfc rick
Beehive single spring. Your not having a lift greater than .600 and your not sustaining long durations at high RPM's. Why beat your cam lobes to death by the increased ramp pressure.
Heres a excerpt from an article,
According to tests completed by COMP, the company’s unique Beehive springs offer a huge number of benefits over stock-style cylindrical springs, including reduced valve spring mass, faster valve acceleration, increased valve train rigidity, and reduced valve train component stress among other benefits.
The word has gotten out in the performance world and folks all over the country are using them for a wide variety of applications from street performance to extreme racing endeavors, boat racing to Baja.
Old Sep 24, 2011 | 07:33 AM
ZZ06's Avatar
ZZ06
i think you missed some of the guys above points. His cam does have pretty high lift and even tho 918's are rated to .600 i personally would and DO have the added security of double springs. Besides if his cam has XER lobes those deliver their own punishment anyways. To the OP i went with a VERY good dual spring. PRC's EHT double spring rated to .675
Old Sep 24, 2011 | 07:56 AM
AU N EGL's Avatar
AU N EGL
dont think it is an XER lode with 222/226
Old Sep 24, 2011 | 08:21 PM
VETTEGUY1977
Ok what is a good beehive spring to look at? Just want to consider all angles.
Old Sep 24, 2011 | 08:42 PM
ZZ06's Avatar
ZZ06
If you decide to go the beehive route then the comp cams 918's are good springs. The PAC 1518 springs are really good as well. They have a higher lift tolerance rated to .650 but retain the single beehive spring.
Old Sep 24, 2011 | 10:41 PM
sfc rick's Avatar
sfc rick
My cam is a TSP 228R .588 lift LSA 112, using PAC 1213 beehive springs.
My heads are stock LS1 using stock valves. My engine is very strong and the valvetrain is light and very smooth i.e. no clack clackity racket. Hence very SMOOTH sound coming from the heads but one hell of a racket coming out the pipes.
Now if you are going for more lift take the PAC 1513's.
Otherwise, more isn't always "better".
Old Sep 25, 2011 | 07:12 AM
AU N EGL's Avatar
AU N EGL
Old Sep 25, 2011 | 07:22 AM
baxsom's Avatar
baxsom
according to the PAC website those 1213s are only good for .550 lift.
you are going to destroy your motor.
Old Sep 25, 2011 | 07:57 AM
sfc rick's Avatar
sfc rick
PAC Single Beehive Valve Springs Rated to .600" Lift
The PAC single valve springs will use your factory seats, seals, retainers, and locks! We recommend stepping up to a dual valve spring kit if you plan to run more than .600" lift and/or a valve larger than 2.08" diameter.
Old Sep 25, 2011 | 08:00 AM
CTD's Avatar
CTD
I have a set of AFR 8019 Red strip springs complete with retainers & seats good for .650 lift if you are interested. They have 300 miles, also comp 5/16 7.450 push rods.
I went bigger
Old Sep 25, 2011 | 08:06 AM
sfc rick's Avatar
sfc rick
I'm sorry to say I made a mistake, I went out to my shop and the Model number is actually 1218 not 1213's so it's still good for a .600 lift. Well within my cam specs.
To valve spring questions
Old Sep 25, 2011 | 08:47 AM
SweetS10v8's Avatar
SweetS10v8
Comps new 918s are good to .625" lift. I run them on my .621" cam and had to shim them to get the correct distance to coilbind.
You dont want to run a dual on such a low lift cam, your springs will be a long way from coild bind, which is less than optimal.
Plus the increased load from the dual springs will actually take away lift, and the weight will make them more likely to be out of control. You need to run a beehive in this situation.
Old Sep 25, 2011 | 09:39 AM
crainholio's Avatar
crainholio
PAC 1518 or PSI springs, beehive either way. And new 1-piece GM seat/seals while you're in there. And a set of Manley valve locks, $40 of cheap insurance against a dropped valve.
Old Sep 25, 2011 | 10:18 AM
The Wrench's Avatar
The Wrench
If your 243 heads will have the hollow valves, then your spring decision is totally different than if you use heavier, solid valves.
DG
