misfire
Old Sep 27, 2011 | 09:15 PM
jacksbadvert's Avatar
jacksbadvert
Default misfire
my 99 c5 has been running like crap. obd codes were p0101, bad maf, plugs completly fouled gas in oil. changed plugs wires maf sensor twice fuel filter/ pressure reg. still missing bad, dual exhaust with h crossover, left side blows hot right side blows cold. HELP.
Old Sep 27, 2011 | 09:34 PM
lucky131969's Avatar
lucky131969
This started all of a sudden? No recent work done?
Old Sep 27, 2011 | 09:41 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
all the plugs or just one ???
Old Sep 27, 2011 | 09:59 PM
Jnape's Avatar
Jnape
I would think that you would have 3xx missfire code and CEL ? Like lucky said, any work done lately?
Old Sep 27, 2011 | 10:06 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
It sort of sounds like an entire bank isn't firing. MAF is having issues of course. Ground wires on rear of driver's side head tight?
Old Sep 27, 2011 | 10:10 PM
jacksbadvert
no work done lately. started all of a sudden was stuck out had to have a shop change plugs aalso had oil changed cuz it smelled like gas, drove home twenty min plugs foulded again changed them second time and new wires juasst in case. shop said code showed bad air mass sensor drove home and changed that also still pulling p0101, also shop said many many misfires but they cleared so i dont know which bank or cly
Old Sep 27, 2011 | 10:11 PM
lucky131969
I'm willing to help.....when you find a computer keyboard...
Old Sep 27, 2011 | 10:13 PM
jacksbadvert
sorry for sloppy spelling
Old Sep 27, 2011 | 10:52 PM
jacksbadvert
I have not had any work done at all except for oil changes at apple chevy in orland park. I was driving at 55 mph when the car started losing power, the check engine light began flashing. I pulled over and the light came on constant. Limped the car to NTB where they scaned for codes, i was told the code for maf out of range and also cylinder misfires in the thousands, unfortunatly no specific bank or cylinder. I was told and shown the plugs were fouled, not being able to drive home i had them replace the plugs. The mechanic said i would be able to drive home with the bad maf sensor so i could replace it myself. Went home and replaced the sensor, started the car and it still was misfiring badly. Checked the plugs, they were fouled again. Replaced the plugs again and new wires. Obd scan showed same code again P0101, returned maf sensor for a new one started car and P0101 returned. checked resistance on injectors, all showed 12 ohms. Like i said earlier, drivers side of dual exhaust blows hot while passenger side blows cold, getting blue spark from all coil packs. I also replaced the fuel filter/ fuel regulator
Old Sep 27, 2011 | 11:10 PM
Jnape's Avatar
Jnape
You say the coil pack ohms out ok and you see spark.
IF spark is at the plug, I can't see how you have so much raw fuel to foul plugs and be cold....?
Old Sep 27, 2011 | 11:18 PM
jacksbadvert
If the fuel regulator had been allowing to much fuel thru could the cat on one side become clogged? if so is it possible to clear or clean without replacing
Old Sep 27, 2011 | 11:19 PM
jacksbadvert
the injectors ohmed at 12, what should the coil pacs show
Old Sep 27, 2011 | 11:29 PM
Jnape's Avatar
Jnape
When you said one side is cold, Was that at the headers or tailpipe?
Old Sep 27, 2011 | 11:37 PM
jacksbadvert
At the tail pipe, there is an h crossover. I mean the air blowing out of the tail pipes is hot on left muffler and cold on right muffler
Old Sep 28, 2011 | 12:04 AM
Jnape's Avatar
Jnape
If hot at the exhaust manifold, I say your cat(s) are toast on that bank.
Old Sep 28, 2011 | 01:36 AM
cdkcorvette7's Avatar
cdkcorvette7
Is it blowing cold air or is it sucking air in on the right? Take a piece of paper and hold it up to the pipes on that side, what you don't want to see is the piece of paper flapping back and forth against the pipe. It should just blow the paper away from it...
Old Sep 28, 2011 | 09:37 AM
dougbfresh's Avatar
dougbfresh
If it's as bad as this there will be a few codes.
To misfire
Old Sep 28, 2011 | 11:52 AM
helga203's Avatar
helga203
I had a cloged cat and i did not have codes, after taking out mid pipes justed removed the cats on both sides(hollowed out) and car has been fine ever since.
Old Sep 28, 2011 | 01:31 PM
dougbfresh's Avatar
dougbfresh
Catalyst Efficiency code should have been set if it was clogged.
Old Sep 28, 2011 | 01:49 PM
lucky131969
...unless a tuner turned it off.....
