Cleaning out the HVAC
I just remembered that I bought some AC parts from a place in AZ a while back. They offer these products.
http://www.ackits.com/merchant2/merc...=coretreatment
A few on their forum claim the $46 kit really works. I gather you drill a small hole to inject the cleaning solution. Worth a try I suppose.
Try this. Clean out ALL your udders in the COWL Drain areas:
The INTAKE AIR for the HVAC system comes from hole on the passengers side of this area:
Heres a picture of the drivers side drain udders with the fender removed.
You can reach them thru here:
Heres what came out of mine and I keep them clean!
On the passengers side theres ONE BIG TUBE. Just pop it out of the cowel and flush it with a garden hose on full stream:
The hose is LONG and pain to get back in so do not remove it!
You can also remove the HVAC fan and reach into the air box and make sure theres no mouse nest in there!
Once you get all the trash out, you can add bleach water and that will kill the mildew and mold in the windshield cowl drains.
BC
BTW, and of particular interest, I see it's mounted on a frame machine. I think I figured out how I can make a set of adapters for mine. I found them online but $650
My machine has dual clamshells on each stand for grabing the pinchwelds on unibody rocker panels. I figure some lengths of angle clamped on the stands with an achoring device welded on to fit in the frame anchor holes. I have it all worked out in my head. Given the gauge steel of the frame, I don't think it will take a lot of force to pull. Oh, mine's the same color too.
