Alternator Output Voltage?
Old Sep 30, 2011 | 02:00 PM
97C5ENVY's Avatar
97C5ENVY
Default Alternator Output Voltage?
What should a typical C5 alternator output voltage be? My DIC readings shows the "Battery Voltage" to fluxuate between 13.5 and 14.1 volts....but is mostly at 13.8 volts. The fluxuation occurs during normal driving....with no radio, no A/C, no turn signals, etc. However it's dipped down to as low as 12.8 when turn signal is used.
Anyway...is this normal or is my alternator slowly going out? BTW it's the orginal factory alternator (1997).
Old Sep 30, 2011 | 02:17 PM
dougbfresh's Avatar
dougbfresh
There is no "typical"-it varies according to load. Typically alternators die in 2 ways, brushes wear out (the alternator completely dies) of the regulator goes and the voltage output is low and/or not DC anymore (1 or more diodes go).
The one thing that kills them quickly is a bad battery forcing it to overcharge. How old is your battery and what voltage is it?
Old Sep 30, 2011 | 02:22 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Default Alternator output voltages
97C5ENVY
The Voltages on the IPC Meter and the DIC DC Volt display is NOT the TRUE output of the alternator or the TRUE battery voltage. To get the actual battery or alternator voltage you MUST measure the voltage directly on the battery terminale or on the output terminal of the alternator.
The voltage/s that you see on the dash meters is derived from a feed that is supplied by the IGNITION SWITCH. If the contacts in the ignition switch are dirty/burnt or defective, those meters and ALL the circuits supplied by the FIVE contacts in the switch can be deficient.
If you have never replaced or repaired your ignition switch, it may be required and resolve a lot of the issues that your seeing.
The alternator output should be 13.7 - 14.7 VDC Depending on battery condition/age/ ambient tempature and system load, it will vary.
Check out this ignition switch post:
-C5 ignition Switch repair - http://forums.corvetteforum.com/c5-t...ch-repair.html
Hope this information helps.
BC
Old Sep 30, 2011 | 07:06 PM
Corvette Don's Avatar
Corvette Don
Originally Posted by Bill Curlee
9
X 1000
i did mine and it fixed about 5 DIFFERENT issues I was having, one being low batt voltage on the DIC even tho my alt was good to go.
Old Sep 30, 2011 | 07:23 PM
Paul 75 L82's Avatar
Paul 75 L82
Ain't it great to have Bill around.
To Alternator Output Voltage?
