98 corvette alternator issue
Old Oct 14, 2011 | 02:53 PM
6SPD98's Avatar
6SPD98
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18- '19
Originally Posted by Bill Curlee
This should help. The 97-98 Schematics should be the same:
There are critical voltages that must be present for the alternator to work properly. Without doing voltage testing,, this will get expensive real quick!
There are some critical connections and wireing on the starter solenoid that effect alternator operation. CHECK THAT before you get too far into this issue.
BC
Thank God you showed up.........
Old Oct 14, 2011 | 03:40 PM
lucky131969's Avatar
lucky131969
Thank God indeed. Order has been restored.
Old Oct 15, 2011 | 11:44 AM
tonyost's Avatar
tonyost
check this out with a volt meter i have 13.5 at the battrey but the dash says 12.5 at the same time i know i should have 14.0 at the battery
Old Oct 15, 2011 | 11:49 AM
tonyost's Avatar
tonyost
still dont't understand why im not getting 14.0 volts testing the alternator says 14 +
Old Oct 15, 2011 | 12:05 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Read the BATT terminal on the BACK of the alternator to ground with the engine OFF and see what it reads.
It should read the same as the battery POSITIVE terminal to ground with the engine OFF.
THEN:
Read the BATT terminal on the BACK of the alternator to ground with the engine running and see what it reads.
It should read the same as the battery POSITIVE terminal to ground with the engine running.
If you read the battery POSITIVE terminal to the alternator BATT terminal with a meter and the connection at the starter solenoid is 100% good, you should read ZERO VDC. If you have a voltage reading, the solenoid connection is poor/compromised:
Connections on Solenoid
If theres a difference between what the battery voltage reads at the battery and what the volt meters in the dash reads,, the delta is caused by dirty / defective contacts in your ignition switch!
-C5 ignition Switch repair - http://forums.corvetteforum.com/c5-t...ch-repair.html
Old Oct 15, 2011 | 12:18 PM
tonyost's Avatar
tonyost
THEN:
thanks i'll start looking therer
Old Oct 16, 2011 | 10:34 AM
tonyost's Avatar
tonyost
not getting the charging system fault any more when car runing getting 14.5 volt at alt at the battery 13.5 in side the car still 12.5
Old Oct 16, 2011 | 10:43 AM
tonyost's Avatar
tonyost
Originally Posted by Ironembraced
12.5 with a volt meter or on your IPC? While engine is running?
getting 14.5 at alt battery reads 13.5 in car 12.5
Old Oct 16, 2011 | 10:45 AM
tonyost's Avatar
tonyost
thanks i;ll will 14.5 at alt 13.5 at battery now going to the starter too see
Old Oct 16, 2011 | 11:14 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Your ignition switch contacts are HOSED!!! Either clean them OR get a new switch.
BC
Old Oct 22, 2011 | 10:15 AM
tonyost's Avatar
tonyost
Thanks guys for all your help the whole thing was a starter isuue had the chev dealer look at he replaced the starter now i have 14.0 at the alternator 13.90 at the battery (runing) the dash still hold at 12.5 to 12.8 but the battery is now charging that god still want to fine out why it say 12.5
Old Oct 23, 2011 | 11:17 AM
tonyost's Avatar
tonyost
Tony
I'll have to check my readings.....when it stops raining.
Do you still get the, "charge system fault" reading on the DIC?
Are all these scenario's at idle or at speed? Sounds like you are checking them at idle.
Did you purchase the Valero, made in France, part number 10246634? This is the only alternator that has the built in monitor circuit that will work in our year car. (Bill Curlee, Evil Twin)
I really hope you get this straightened out, I hate it when I can't drive my car.
the starter was bad the alt is at 14.0 battery is 13.90 running gage in car still say 12.5 to 12.8
Old Oct 23, 2011 | 11:31 AM
  #33
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
YOUR IGNITION SWITCH IS CAUSING THE VOLT METERS ON THE DASH TO READ LOW!!!!!!!!!
Plain and simple!! Rebuild or replace the SWITCH part and you will see very close to actual battery voltage on your meters.
Old Oct 23, 2011 | 11:49 AM
  #34
tonyost's Avatar
tonyost
i know your right going to check the fuse frist are a number like eng ing fuse 19 will it say it on the fuse
