Cam Install
Old Oct 9, 2011 | 09:04 PM
walleyejack's Avatar
walleyejack
Default Cam Install
Just lately I found on here a thread about cam install, and I can t find it and didn t bookmark it, anyone have any ideas where I can locate it again please.
Thanks Al
Old Oct 9, 2011 | 09:14 PM
shockwaveAZ's Avatar
shockwaveAZ
found this if it helps.
http://www.ls1howto.com/index.php?article=23
Old Oct 9, 2011 | 09:52 PM
walleyejack
Default cam install
Originally Posted by shockwaveAZ
Thank you, it isnt the one I was looking at,but I am sure it will work,took me a bit to find the C5 cam install.
Thanks for your help
Al
Old Oct 9, 2011 | 10:13 PM
MT0911's Avatar
MT0911
ls1howto is the place to be for info on installs. Use that coupled with the advice on here and you'll be set. Good luck man!
Old Oct 9, 2011 | 10:55 PM
walleyejack
Thanks man, looks like a lot of work for one person, but I am sure I can handle it, I did it in the 70's so I can do it now
Was gonna send it out to have heads and cam done,but for $1600 I think I have all winter to do it.
al
Old Oct 9, 2011 | 11:00 PM
MT0911's Avatar
MT0911
al
Yep the labor costs is what kills me. I love working on both of my cars but there are some jobs that I'd sometimes rather just pass on lol. But... then again, I don't know if I trust anyone else touching my cars .
Realistically, these motors aren't that bad to work on though. There are some incredibly knowledgeable guys on CF and you have lots of resources so you should be just fine.
Old Oct 9, 2011 | 11:17 PM
sami85L98's Avatar
sami85L98
If you doing just Cam than look Fbody Cam and valve sping install as well, and than come down at C5:head cam install and look for how to remove rack (for some it was a pain in **** but since iam a mechanic and had no trouble at all just need 18mm flare socket W/long 15-20" extesion, once crack loose than you can use reguler combination wrench. dont move completely just push on passenger side.
If you remove the hood than it makes lot easier, just mark fine sharpe or paint mark right beside hood bolts before remove hood, this way lot easier to install and dont have to align.
ask any question if you need to, its a lot of work but doable.
Old Oct 9, 2011 | 11:22 PM
walleyejack
thanks men, ya i can dot the cam and heads ok, just taking the front end apart i am not exicted about and trying to wrestle the rad out might me a trick,may be able to do it with help of overhead block and tackle,looks more awkword than anything.
THanks
Old Oct 9, 2011 | 11:25 PM
walleyejack
I ll just drop it off in your driveway then Sami, give you something to do in your spare time
Old Oct 10, 2011 | 02:39 AM
Lothar34's Avatar
Lothar34
The radiator isn't hard to remove. The real pain in the *** is the steering rack.
Old Oct 10, 2011 | 09:50 AM
sami85L98's Avatar
sami85L98
Did not notice you live in whitby, well i dont have garage or else i would do in a heart beat. But if you need help i wont mind coming over to help ya. I will be changing my present cam to something sleeper this winter at my borrowed friends garage though.
To Cam Install
