Steering Lock
Old Oct 10, 2011 | 08:14 PM
RJB34's Avatar
RJB34
Default Steering Lock
I have a 2004-Z06 with 6 speed manual. Whenever I start the vette, the message "Steering Column Locked" is displayed on the readout. I hit the reset to get rid of it, the other read outs work fine. The dealer (not a chevy dealer) is very knowlable, says that his 2009 does to, he told me not a worry about it. The local mech. said that it will start but you never know when the column will actually lock. He wants over $200 to put a by-pass in. I called chevy and they said that there were no recalls on this but they have always had this problem. I don't want to guess what they would charge to fix it.
Any ideas???
Old Oct 11, 2011 | 12:12 PM
Jewjenk's Avatar
Jewjenk
Do a search on column lock.....................steering locked etc........lots of posts.......................
Old Oct 11, 2011 | 12:29 PM
cdkcorvette7's Avatar
cdkcorvette7
http://forums.corvetteforum.com/c5-t...ky-please.html
Old Oct 11, 2011 | 01:28 PM
RJB34's Avatar
RJB34
Default Doubled check
Just went to the garage and it said "Service Column Lock". Sorry There is no lock with the key out
Old Oct 11, 2011 | 03:22 PM
dougbfresh's Avatar
dougbfresh
AND, does the steering column LOCK with the key removed?
Old Oct 11, 2011 | 06:04 PM
RJB34's Avatar
RJB34
Default Service lock
No on both
Old Oct 11, 2011 | 07:11 PM
dougbfresh's Avatar
dougbfresh
So you either have some GM recall and/or a CLB installed-YOU need to figure out which.
Old Oct 11, 2011 | 07:41 PM
RJB34's Avatar
RJB34
Default Service Lock
Just got done talking to GM. They did a more in-depth reseacrch than my local chevy dealer. According to the research, there was a recall and the previous owner had the unit serviced. I guess they didn't fix it completly but the recall was closed and anymore work would be done at my expense. My electrical guy said they probably bypassed the locking mech. (which I no longer have) so the lock up or fuel shut off should not occur. I just have to put up with that message being displayed. I just hit reset and it goes away. Thanks for the help and feedback.
Old Oct 12, 2011 | 06:47 PM
RJB34's Avatar
RJB34
Default Steering Lock-Reply from Gene
I sent Gene my vin. Under the heading of Transaction History are the following
7-18-07 E7690-Sensor, Steering Wheel Rotation-Replace
odometer-59,870
4-29-07 E7200-Inginition Lock Cylinde Replacement
odometer-55,846
Required Field Actions:
Type Number Original Nbr Descrp. Status
product safety NO40006 04006 Electronic Closed
recall Column Lock
System
To Steering Lock
