Power seat problem.
Old Oct 11, 2011 | 09:30 PM
396375's Avatar
396375
St. Jude Donor '08-'09
Default Power seat problem.
I bought some nice used Z06 seats.They didn't come with tracks,so I bought a power track.The seat didn't come with a switch panel and I couldn't find one.I put the seats in and the passenger track is non power and works fine.I thought I could put power to each motor and adjust the seat position which was no problem.The problem is the seat track has hinged levers at the front and a set at the back.You can push the seat up and down at the front of the seat because of these hinged levers.It moves about 4"s up and down.In other words when you are sitting in the seat and you accelerate the seat goes tilts back all of a sudden as if the front track was not bolted down.The only way to keep the seat stable is to power the seat all the way back and then tilt the upper half with the side lever back far enough to rest on the rear angled bolster.Great if you are 6'8" but I'm only 5'11" and can barely reach the wheel.
HELP.
Old Oct 12, 2011 | 08:20 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I don't know what to tell you. You are mixing components so things aren't going to work the way you wish. I would suggest that you contact a corvette recycling company or salvage and start acquiring the things you need. Did your car have the sport seats in it before or manual seats?...powered seats vs non-powered.
Old Oct 12, 2011 | 09:16 AM
corvette c5er's Avatar
corvette c5er
i have the same problem
and i found on amazon (seat track repair) that i have ordered few days ago its like small brakes to be replaced with old ones but i still didn't receive the item
Old Oct 12, 2011 | 09:19 AM
396375's Avatar
396375
I had sport power seats before.I don't think anything is different as far as the tracks go.
Old Oct 12, 2011 | 10:18 AM
dgrant3830's Avatar
dgrant3830
Why not put the sport seats back in so the electrical/mechanical all work, then have the seat covers replaced with your Z06 covers?
Old Oct 12, 2011 | 11:53 PM
396375's Avatar
396375
Fixed.Someone had powered the track while it was out of the car and off the seat.Hinges were past their intended range.
To Power seat problem.
