Cracked Diff side Cover
Old Oct 20, 2011 | 10:24 AM
stevenm357's Avatar
stevenm357
Default Cracked Diff side Cover
During a recent exhibition of wheel hop, i cracked my passenger side cover.
I can't find a part number, price or anything I've searched until i'm blue in the face.
I've found DTE's side cover but $400-500 for a cover, Not something I can afford right now. It's a pretty good crack
Thankfully I made it on a 500 mile journey after the crack! I had no idea it happened, still have a tiny bit of fluid, also is there a way to tell if the rear end internals were damaged?
Old Oct 20, 2011 | 10:27 AM
lucky131969's Avatar
lucky131969
In my opinion, if the wheel hop event was pronounced enough to crack the side cover, that differential needs to be pulled and inspected.
Old Oct 20, 2011 | 10:45 AM
stevenm357's Avatar
stevenm357
Humm.. I keep looking for a reason to go to 3:90 gears..... lol. Between that and the clutch this winter i would be quite poor.
Old Oct 20, 2011 | 11:06 AM
lucky131969
It comes with the territory.....if you wanna play.....you gotta pay.
The part number I have for the RH cover is : 12458148.
Old Oct 20, 2011 | 11:31 AM
stevenm357's Avatar
stevenm357
Thought the clutch would go first..... atleast the car made it home!
Old Oct 20, 2011 | 11:34 AM
rebelheart's Avatar
rebelheart
Old Oct 20, 2011 | 04:15 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
WOW! That sucks!
If it were me,,,,, I would disassemble the differential and insp. While you are in there, either harden the internal parts or install a hardened rear with a gear ratio of your pick!
Good time for a clutch up-grade.
Also time for an ECS brace , Pfdat differential mount and some C6 suspension parts. All that helps to significantly reduce wheel hop. It will NOT eliminate it,, just reduce the frequency!
Some interesting links!
- C5, ragtopws6 , Upgrading your C5 rear with C6 Z06 guts, : http://forums.corvetteforum.com/c5-g...-z06-guts.html
- C5, Its_Go_Time, Output Shaft Install - Left and Right: http://forums.corvetteforum.com/c5-t...post1573407966
- C5 Differential Seal replacement: http://forums.corvetteforum.com/c5-g...on-photos.html
Old Oct 20, 2011 | 10:14 PM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Thanks Bill!
Old Oct 20, 2011 | 10:53 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Originally Posted by DOUG @ ECS
Thanks Bill!
Any time brother! Great product!
BC
Old Oct 22, 2011 | 07:56 PM
Rick@RKT Performance's Avatar
Supporting Vendor
St. Jude Donor '08-'09-'10-'11-'12, '14-'15-'16-'17-'18
If the diff didn't make any noise coming home, it should be fine but I would still have it inspected. Another vote for ECS trans/diff mount!!!!!!!! I recommend them to all my customers!!!
__________________
To Cracked Diff side Cover
