99frc Body Control Moduel problem?
Old Oct 20, 2011 | 10:51 PM
socal99's Avatar
socal99
Default 99frc Body Control Moduel problem?
The car was running just fine. Stopped for a bite to eat came out and turned the key, nothing. Pulled the key out double cheked the clutch tuned the key nothing. dic said pull key wait 10 sec, did so tried again nothing and now the guages wont sweep and no dic. Push started the car, fired right up and got it home still wont start w key. Pulling alot of bcm codes, but it was doing that before this problem. The car is my stock dd, any input? what bcm are inerchangeable?
Old Oct 20, 2011 | 11:03 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Seriously doubt if its a BCM issue. Read and post the DTCs..
After you post what DTCs you find,,, Please clear ALL the DTCs and then try to start the car. List the DTCs that come back.
Also make SURE that your battery is FULLY CHARGED and in 100% operating condition.. What is the battery voltage that you read directly on the battery terminals and what voltage do you read on the IPC volt meters with the key ON?
Just having a dead battery will cause your reported symptoms.
BC
Old Oct 20, 2011 | 11:47 PM
socal99's Avatar
socal99
batts a year old optima in good condition its my daily driver, cleared the codes they all came right back there has to be about 20-25 codes. IPC?
Old Oct 20, 2011 | 11:53 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Please list them ALL. Its important!!
BC
Old Oct 22, 2011 | 02:11 AM
socal99's Avatar
socal99
I went out to the car this morning put the key in and it fired right up like normal. Drove it to the other driveway turned it off, gave it a sec tried to fire it up nothing same thing.This time I noticed when i jigled the key a bit it fliked some dash lights. Did it just once. Could it just the the key and or key cylinder.
Old Oct 22, 2011 | 02:38 AM
socal99's Avatar
socal99
Old Oct 22, 2011 | 08:38 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Rebuild your ignition switch
- C5 ignition Switch repair - http://forums.corvetteforum.com/c5-t...ch-repair.html
Old Oct 22, 2011 | 08:45 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I agree with Bill too. Ignition switch. BTW, did you know you can get to the codes directly from the DIC?
Old Oct 22, 2011 | 08:53 AM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
READING YOUR Engine Diagnostic Trouble Codes (DTC)
This procedure should be carried out any time you experience a problem with your C5. Most inexpensive store bought aftermarket code readers will ONLY read power train DTC’s. Reading the DTC’s with the C5 built in code reader will allow you to read ALL the modules in the vehicle.
The Diagnostic Display Mode is entered with the following procedure:
1) Turn on the ignition but don't start the engine.
2) Press the RESET button to turn off any warning messages. (i.e. door open, trunk open ect)
3) Press and hold the OPTIONS button
4) While holding OPTIONS, press FUEL button four times within a 10 -second period.
Initially, the on-board diagnostics go into an Automatic Mode which will cycle through each module and shows diagnostic codes in a pre-set sequence: PCM - TCS - RTD - BCM - IPC - RADIO - HVAC - LDCM - RDCM - SCM - RFA. All codes will be displayed for each module. ( i.e. PCM = 4 codes) If none are present in a given module, you will see No More Codes on the display.
There are two types of diagnostic codes, Current and History designated with a letter suffix, “C” or “H”. A current code indicates a malfunction is present in the module displaying data. A history code indicates a problem existed sometime in the last 40 or 50 ignition cycles. When not accompanied by a current code of the same number, it's potential evidence of a previous problem, now resolved, that was not removed by clearing the codes. More likely it's an indication of an intermittent malfunction.
Intermittent codes are the most challenging of the diagnostics. An intermittent code may have happened once, may have happened more than once but is inconsistent or may be happening on a regular basis but not at the time the codes are displayed. History codes can also be caused by a current malfunction in a system that is not operating at the time codes are displayed. An example is the rear window defogger which doesn't operate until the Body Control Module detects engine rpm. For history codes set by a module that does not operate with the key on and engine off, a special diagnostic tool called a Scan Tester is necessary to properly diagnose the malfunction.
Once the system has displayed all modules, it goes into the manual mode which allows selection of each module using combinations of Driver Information Center buttons. Manual mode can also be entered during the automatic sequence by pressing any button except E/M. Once the display shows Manual Diagnostics, select a module by pressing the OPTIONS button to go forward or the TRIP button to go back. Once a module is selected, a code is displayed, and if more than one are present; press GAGES to go forward or FUEL to go back.
To exit the diagnostic mode at any time, press E/M. If you want to erase codes in a given module, press RESET To reset the codes once in manual mode, press and hold RESET until it displays NO CODES Press OPTIONS to go to the next module. Repeat the steps until you have reset the codes in all the computer modules.
NOTE!! Only reset the codes IF you want to - it is NOT necessary to do this. Clearing a code does not repair a problem. You are simply erasing the evidence of it in the module's memory. If you clear the code/s, and extinguish the Check Engine Light, your emissions status ready will NOT allow you to pass an emissions test until you have completed the required driving cycles. There are a few body module DTC’s that if set will prevent the module from operating properly. Once the DTC is cleared, the module will return to full function. This is not true for power train DTCs.
If you have never read and cleared your codes, there will probably be a lot of old history DTCs. It is recommended that you clear your codes and see if any come back during a driving cycle. Those are the ones that you need to concentrate on diagnosing.
Once you have the codes, the next question is: What to do with the information?
First, consult the factory service manual. Any serious C5 Do-It-Yourself owner should invest in the Corvette Service Manual of the appropriate model year. The Service Manual is really a requirement if you want to understand and work on your C5.
NOTE and a WARNING. You can read the DTCs while the engine is running. I pull mine up all the time while driving.
WARNING. Don’t become distracted while reading DTCs while your driving and cause an accident!!!!! Use common sense and drive safe.
These are some very good C5 Diagnostic Trouble Code (DTC) explanation web sites!!! They also explain how to read the DTCs
Here are some very good sites that explain what DTC mean:
http://www.gearchatter.com/viewtopic11755.php
http://www.obd-codes.com/trouble_cod...d-ii-codes.php
Make sure to include the H or C suffix when you post your DTCs!!
Old Oct 22, 2011 | 12:53 PM
socal99's Avatar
socal99
thanks all, i cant read from the DIC it wont come on these screen shots are from hp tuners
Old Oct 27, 2011 | 02:16 PM
socal99's Avatar
socal99
So I took the switch apart and cleaned it. It wasnt too bad but none the less it may fix other issues, but it didnt fix the no start/ no guage/DIC situatiion. Anybody have any other ideas of what the problem could be.
Old Oct 28, 2011 | 05:36 PM
socal99's Avatar
socal99
got a call from the dealership. its eithere the key cylinder or colum lock. starting w the key cylinder and a new key (i dont have a spare)
Old Oct 28, 2011 | 11:13 PM
rkhegler's Avatar
rkhegler
Change out the key cylinder. Easy fix and not expensive if you do it yourself. There is a thread on the forum with step by step instructions. Bill Curlee is the man. Post #7!
Old Oct 30, 2011 | 12:05 AM
socal99's Avatar
socal99
all about doing it my self but just dont have time so its getting fixed and going straight to the body shop for the tigershark nose to match the rear and lingefelter magnacharger hood.
To 99frc Body Control Moduel problem?
