Auto lock system?
Old Oct 21, 2011 | 06:52 PM
Wicked Whitey's Avatar
Wicked Whitey
Default Auto lock system?
Our 98 coupe which we had set to lock/unlock automatically then changed to only lock/unlock with the fob. But still have the following problem. With both sets of our keys hanging on the key rack, just walking into the garage the car will lock....then walking around the garage it will unlock....then lock as long as there is a warm body in or even approaching the garage from inside the house.
Any suggestions to cure or exorcise my Vette will be appreciated.
WW
PS I have gone through the fob learn process to no avail.
Old Oct 21, 2011 | 07:26 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
There should be a slide switch on your FOB,,, make sure its off. In the DIC,, use the OPTIONS and set up the FOB Function to ACTIVE OFF
FOB operation is in your owners manual in chapter 2
BC
Old Oct 21, 2011 | 09:58 PM
65GGvert's Avatar
65GGvert
Or move the fobs farther from the car.
Old Oct 22, 2011 | 08:50 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I'll add in here...good old fashoned pocket dust will cause the slide switch to effectively turn on, even if the slide switch is in the off position. Blow it out real good.
To Auto lock system?
