No Comm 2001 Z06
...Anyways I rechecked all the grounds had a second opinion on my bcnm for cleanliness and I figure tomorrow I will order a new head unit unless there is anything else you think I should try first?
You should still open it and see if theres something obvious..
BC
However, I was forced to push the car back on the road this week due to some events of life happening. I figured that at worst I wouldn't have my ac head unit plugged in and I could drive the car until I could fix it.....
NOT TO BE>>>
I drove the car for about an hour, then on my way home I noticed my interior lights were flashing every few minutes; with the blinker, starting from a dead stop, and randomly.. then my message center started telling me trunk open even though it wasn't, the interior lights started to blink with the blinker. Then the interior lights decided to come on and stay on until I got home and I disconnected the battery!
I am going to recheck the grounds in the morning but is there a chance this is all related and maybe tethered into my ECM? Only reason I am wondering is I can hear something clicking off and on- down in the floor board when all this is going on.
I made a new grounding point on g102 and cleaned the others again.
Then I removed one wire at a time from the ac head unit. Only the white (the wire that runs between the ac head unit and the computer) would make the reduced horsepower mode and no comm situation go away.
Because of this I am convinced my ac head unit is causing the issue. I am ordering one today and it should be here Saturday. Hopefully this is it!
If anyone however happens to have a picture of how the wires are suppose to go in the connector for the a/c head unit please post it or let me know... I should have take a picture before I disconnected them and only have one possibly out of place. The orange wire I am unsure if it goes directly under the pinkish wire or if it skipped a spot or two I am pretty sure it goes directly under the pinkish but I am second guessing myself....
Thanks!
it shows the side and the orange is fine.... however a few wires on the other side I am questioning now and its hard to see in the picture... If anyone has a pic of the other side or otherwise knows the layout and correct pattern I would appreciate it. stumbling my way through getting this thing back to working condition one day at a time...
Connector Part Information
12045470
32-Way F Micro-Pack 100 Series (NAT)
Pin
Wire Color
Circuit No.
Function
C1
BLK
150
Ground
C2
LT BLU/BLK
590
Driver Solar Sensor Signal
C3
DK BLU
1646
Air Temperature Door Position Signal-Auxiliary
C4
Not Used
C5
BRN
41
Ignition 3 Voltage
C6
WHT/BLK
1236
Air Temperature Door Control-Auxiliary
C7
DK BLU
1199
C8
LT BLU
733
C9
Not Used
C10
YEL
1791
5 Volt Reference
C11
TAN
63
Blower Motor Speed Control
C12
ORN
540
Battery Positive Voltage
C13-C15
Not Used
C16
YEL
390
Instrument Panel Lamp Supply Voltage - 3
D1
GRY/BLK
1798
Ground
D2
DK GRN
734
Inside Air Temperature Sensor Signal
D3
LT GRN/BLK
735
Outside Air Temperature Sensor Signal
D4-D7
Not Used
D8
DK GRN
1394
Recirculation Mode Valve Solenoid Control
D9
LT GRN
66
Mix-Blend Mode Valve Solenoid Control
D10
PPL
1397
Lower Mode Valve Solenoid Control
D11
LT GRN
1395
Upper Mode Valve Solenoid Control
D12
WHT
1038
HVAC Class 2 Serial Data
D13
PNK
1396
Defrost Mode Valve Solenoid Control
D14-D16
Not Used
Thanks everyone especially Bill and lucky for all suggestions and guidance! I only need to do a few little things (get a new key and replace my e-brake) to be 100% happy with my baby!
