C5 problems
Old Nov 6, 2011 | 07:37 PM
DelD's Avatar
DelD
2nd Gear
Default C5 problems
I just purchased a 1999 convertible with 38860 on the clock. Two problems have poped up. First, the seat memory is intermittent. Second,
the car shuts off (intermittently) when put in drive and starts to move. It does it several times and later is fine.
The dealter said that the seat memory module is bad but GM does not have any in stock at at any dealers.
They said they could not duplicate the shutting off.
Any help would be greatly appreciated!
Thanks,
Del
Old Nov 6, 2011 | 07:42 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
When your car has the issues stated,,, WITHOUT TURNING OFF the IGNITION,,, read and pos your DTCs
Being a NEW C5 owner,, here ya go
READING YOUR Engine Diagnostic Trouble Codes (DTC)
This procedure should be carried out any time you experience a problem with your C5. Most inexpensive store bought aftermarket code readers will ONLY read power train DTC’s. Reading the DTC’s with the C5 built in code reader will allow you to read ALL the modules in the vehicle.
The Diagnostic Display Mode is entered with the following procedure:
1) Turn on the ignition but don't start the engine.
2) Press the RESET button to turn off any warning messages. (i.e. door open, trunk open ect)
3) Press and hold the OPTIONS button
4) While holding OPTIONS, press FUEL button four times within a 10 -second period.
Initially, the on-board diagnostics go into an Automatic Mode which will cycle through each module and shows diagnostic codes in a pre-set sequence: PCM - TCS - RTD - BCM - IPC - RADIO - HVAC - LDCM - RDCM - SCM - RFA. All codes will be displayed for each module. ( i.e. PCM = 4 codes) If none are present in a given module, you will see No More Codes on the display.
There are two types of diagnostic codes, Current and History designated with a letter suffix, “C” or “H”. A current code indicates a malfunction is present in the module displaying data. A history code indicates a problem existed sometime in the last 40 or 50 ignition cycles. When not accompanied by a current code of the same number, it's potential evidence of a previous problem, now resolved, that was not removed by clearing the codes. More likely it's an indication of an intermittent malfunction.
Intermittent codes are the most challenging of the diagnostics. An intermittent code may have happened once, may have happened more than once but is inconsistent or may be happening on a regular basis but not at the time the codes are displayed. History codes can also be caused by a current malfunction in a system that is not operating at the time codes are displayed. An example is the rear window defogger which doesn't operate until the Body Control Module detects engine rpm. For history codes set by a module that does not operate with the key on and engine off, a special diagnostic tool called a Scan Tester is necessary to properly diagnose the malfunction.
Once the system has displayed all modules, it goes into the manual mode which allows selection of each module using combinations of Driver Information Center buttons. Manual mode can also be entered during the automatic sequence by pressing any button except E/M. Once the display shows Manual Diagnostics, select a module by pressing the OPTIONS button to go forward or the TRIP button to go back. Once a module is selected, a code is displayed, and if more than one are present; press GAGES to go forward or FUEL to go back.
To exit the diagnostic mode at any time, press E/M. If you want to erase codes in a given module, press RESET To reset the codes once in manual mode, press and hold RESET until it displays NO CODES Press OPTIONS to go to the next module. Repeat the steps until you have reset the codes in all the computer modules.
NOTE!! Only reset the codes IF you want to - it is NOT necessary to do this. Clearing a code does not repair a problem. You are simply erasing the evidence of it in the module's memory. If you clear the code/s, and extinguish the Check Engine Light, your emissions status ready will NOT allow you to pass an emissions test until you have completed the required driving cycles. There are a few body module DTC’s that if set will prevent the module from operating properly. Once the DTC is cleared, the module will return to full function. This is not true for power train DTCs.
If you have never read and cleared your codes, there will probably be a lot of old history DTCs. It is recommended that you clear your codes and see if any come back during a driving cycle. Those are the ones that you need to concentrate on diagnosing.
Once you have the codes, the next question is: What to do with the information?
First, consult the factory service manual. Any serious C5 Do-It-Yourself owner should invest in the Corvette Service Manual of the appropriate model year. The Service Manual is really a requirement if you want to understand and work on your C5.
NOTE and a WARNING. You can read the DTCs while the engine is running. I pull mine up all the time while driving.
WARNING. Don’t become distracted while reading DTCs while your driving and cause an accident!!!!! Use common sense and drive safe.
These are some very good C5 Diagnostic Trouble Code (DTC) explanation web sites!!! They also explain how to read the DTCs
Here are some very good sites that explain what DTC mean:
http://www.gearchatter.com/viewtopic11755.php
http://www.obd-codes.com/trouble_cod...d-ii-codes.php
Make sure to include the H or C suffix when you post your DTCs!!
Pos the DTCs and then CLEAR ALL OF THEM and see what DTCs come back.
Bill
Old Nov 6, 2011 | 07:45 PM
Silverbullet00's Avatar
Silverbullet00
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
OP, You are in good hands! B.C. Will help you figure it out!
Old Nov 7, 2011 | 09:20 PM
Slynch1033's Avatar
Slynch1033
4th Gear
Similar problem here. I pulled the drivers seat out this weekend to repair the rocking chair that is common to C-5's as I read. 2002 C5 with 73k. The seat is now crazy. When you press the button to slide back, it goes forward and vise versa. When you press the unlock key fob the seat used to go all the way to the rear (when tuning off car as well) and then go back to memory when started. Now the seat goes all the way forward. I reversed the motor wires as it is non polarized but the seat would only move in small increments in the correct direction. Am I looking at a seat module or would it be in the BCM somewhere?
The part number on the seat control module is 10435193. It is not the original 02 seat, the dealer swapped the seat when I bought it as the track on the one in the car was broken, not just rocking.
Thanks for ANY help!!!!!!!!!!!!!!!!!!!!!!!!!
Old Nov 7, 2011 | 10:30 PM
65GGvert's Avatar
65GGvert
You need to start your own thread instead of hijacking someone else's who is seeking help. The questions and answers won't mesh up and will confuse both of you. Click on new thread and post your issues.
To C5 problems
