Rebuilt Rear and Experiences
Old Nov 15, 2011 | 08:24 AM
mfile2000's Avatar
mfile2000
Default Rebuilt Rear and Experiences
I am about to bring my vette in for rear end work. Planning on going to Cartek in Garwood NJ. The question is how can I be assured the rear doesn't go out again? Anyone have experince with Cartek? And why would the rear go out in the first place.
Thanks for the input.
Old Nov 15, 2011 | 10:23 AM
jimcork1's Avatar
jimcork1
I would buy a new diff if available or Factory reman.
If the depth of pinion is set incorrect you will have whine / hum.
If the ring gear side clearance is set incorrect you will have clunk when shifting F to R.
You must have a nice tooth pattern in center of ring gear from proper seating of the pinion.
Reusing old gears and shims will not insure you have correct settings.
These are critical.
If you can get reman set by factory that is the way I would go.
This does NOT mean you won't get a good rebuild but I have seen many shops do this type of rebuild and then after have a hum/whine and say. "this is normal break in".
It IS NOT NORMAL!. There should be no more noise on a rebuilt than a new one. Don't accept any noise that wasn't there previous.
The only bad thing is there is no way to quantify how much noise on a rebuild is NORMAL.
For noise it will be your word against theirs. So be sure you take the right steps to insure a quality rebuild.
Old Nov 15, 2011 | 10:25 AM
lucky131969's Avatar
lucky131969
Can you elaborate on the problem?
Old Nov 15, 2011 | 10:38 AM
mfile2000's Avatar
mfile2000
The car runs great. The whine has turned into a hum. Cartek will rebuild for $1,500. The dealer will swap out for $3,000. Both come with a 12 month 12,000 mile warranty. The question is why did this happen and will it happen again?
Old Nov 15, 2011 | 11:37 AM
Dope's Avatar
Dope
Resident moron
I don't think anyone can answer the questions you've posed without any relevant details. Maybe ask Cartek once they disassemble your rear? There's lots of things that could have gone wrong and you can only give an accurate diagnosis once you've taken it apart.
Dope
Old Nov 15, 2011 | 11:51 AM
Redvette_22's Avatar
Redvette_22
PM sent
Old Nov 15, 2011 | 02:26 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
WOW!
If you have a STOCK rear and it had ISSUES, putting in another STOCK rear may solve the issue but IF,,, you’re driving style KILLS rear ends, you need to get a hardened rear with the proper upgraded parts.
Best way to do that is to have a qualified shop build your rear to match your driving style and car usage criteria. (i.e. Drag race, auto cross, aggressive street driving, ect.....)
I put C6 ZO6 parts in mime to get to the next level without breaking the bank.
Before anyone can fully answer your questions, you need to provide a LOT more info.
Mileage on car??
Past service done to the rear??
Driving Style??
Eng HP/Tq??
Suspension Mods??
Goals??
CASH on hand / available for repairs/mods??
etc....................
" I don't think anyone can answer the questions you've posed without any relevant details. Maybe ask Cartek once they disassemble your rear? There's lots of things that could have gone wrong and you can only give an accurate diagnosis once you've taken it apart.
Dope
Very valid point! What failed in the current installed rear???????????????? 100% Agree!!
BC
Old Nov 15, 2011 | 02:36 PM
mfile2000's Avatar
mfile2000
Mileage on car?? 62,000
Past service done to the rear?? Nothing I know of, bought used.
Driving Style?? Usually Stupid, but mostly uneventful
Eng HP/Tq?? Stock
Suspension Mods?? Stock
Goals?? Silence in Rear, maybe 4.10 gears
CASH on hand / available for repairs/mods??Maintenance Only
Old Nov 16, 2011 | 09:18 AM
jimcork1's Avatar
jimcork1
Eng HP/Tq?? Stock
IMO 4:10 gearing will increase your RPM at 70 mph by about 800 and cut fuel mileage by 9 mpg. Your acceleration will be way faster but your top end will probably drop by 25 mph. Just my opinion of course.
Old Nov 16, 2011 | 09:38 AM
mfile2000's Avatar
mfile2000
WOW. The rpms I can find on some charts, but the 9 mpg drop? So on the highway cruising along in 6th gear, I get 31 MPG would now drop me to 22 MPG? I didn't think it would be that much.
Old Nov 16, 2011 | 11:51 AM
Redvette_22
My 98 A4 with 4.10's only lost 1.5 MPG on the highway but was still 26+
Old Nov 16, 2011 | 03:34 PM
Dope's Avatar
Dope
Resident moron
Not even close. I am running a heads/cam package with big tires and 4.10s and I get 26-27 on the highway.
Dope
Old Nov 16, 2011 | 10:14 PM
Lloyd Christmas's Avatar
Lloyd Christmas
IDK about a 9mpg loss. I was still getting 24mpg on the hwy in my heavier, much more powerful Camaro with 4.11s. I don't know if its even that bad with an A4.
Old Nov 17, 2011 | 08:13 AM
mfile2000's Avatar
mfile2000
Thanks all. Call me a *ussy but I'm going to compromise with 3.90s. Hopefully I'l bring it Saturday. If all goes well I'll pick up my Triumph Sprint ST, bring it home and bring the vette in on the same day. Cha-ching!
To Rebuilt Rear and Experiences
