Car has Idle problems...Read Codes
Old Nov 17, 2011 | 03:23 PM
Toxiclemonade's Avatar
Toxiclemonade
Default Car has Idle problems...Read Codes
Okay guys, car is a 2000 vette, 6 speed with 130k on the clock. The car recently has been running like crap, especially at idle. I figured it was adjusting to the colder weather we've had here lately but it hasnt gone away. I've pulled the codes and this is what I got:
PCM- P0102 Maf Circuit Low- maf sensor is less than two years old, could it be dirty? Should I replace it? Would this cause bad idle?
Also, when I get near the redline the car has recently gone into the "safe mode" and sounds like it is running on 4 cylinders with 0 power. Could this be due to worn plugs? No codes that I've pulled have said anything about this and it only happens if, say, I downshift from a higher gear to a lower gear and get near the redline. Any input is appreciated. Thanks.
-Ryan
Old Nov 17, 2011 | 03:30 PM
lucky131969's Avatar
lucky131969
-Ryan
Here you go:
File Type: pdf
Old Nov 17, 2011 | 07:43 PM
Toxiclemonade
thank you. I will try to track down what is going on with this.
Old Nov 17, 2011 | 11:15 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
COLD WEATHER will NOT have ANY ill effects on your car. If ALL the systems are working correctly,, it will run correctly in the Desert and in the Arctic Tundra without even trying!
You have a MAF issue. First check for a dirty MAF, then the wiring and connections. Then clear the DTCs and see what you have.
The intake air ducting between the MAF and TB MUST be completely sealed (AIR TIGHT) so the engine gets the proper metered air.
BC
Old Nov 18, 2011 | 01:11 PM
Toxiclemonade
BC
Hahah I was hoping it was just adjusting. I bought some MAF cleaner and new plugs. Will get at it this weekend and report back. I checked all connections and there don't seem to be any leaks, but ill get some carb cleaner and see if it affects idle.
Old Nov 18, 2011 | 05:22 PM
MG RED 99's Avatar
MG RED 99
Correct me if I'm wrong but don't get carb cleaner I believe they make specific MAF cleaner.
Old Nov 18, 2011 | 06:53 PM
Toxiclemonade
Sorry for the confusion, i meant to spray around connection areas of the intake to see if there is a leak. I bought MAF spray for the MAF.
Old Nov 18, 2011 | 07:08 PM
lucky131969
Have you followed the troubleshooting procedure, and done checks with a meter?
Old Nov 19, 2011 | 08:05 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
BTW, do not attempt to physically touch the MAF sensor(s) themselves. You can easily ruin it.
To Car has Idle problems...Read Codes
