Loose Harmonic Balancer
Old Nov 19, 2011 | 08:39 AM
buddyroth's Avatar
buddyroth
Default Loose Harmonic Balancer
Anyone have trouble with a harmonic balancer coming loose? If so, what was the solution?
Thanks, BR
Old Nov 19, 2011 | 08:41 AM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
Thanks, BR
This is common. Do a search. Replacement is your only option if you are talking the outer portion of the balancer. If it is loose on the crankshaft, someone may have reused the attachment bolt. The bolt needs to be replaced and properly torque.
Old Nov 19, 2011 | 09:31 AM
vettenuts's Avatar
vettenuts
Once they come loose and spin relative to the crankshaft it is sometimes best to just replace it. Was it recently worked on?
Old Nov 19, 2011 | 11:05 AM
lionelhutz's Avatar
lionelhutz
If it has spun on the hub then you should likely pull-it and replace it with an aftermarket unit so you can pin the crank. Pinning and a properly torqued new bolt should work even if the press-fit is weak.
You need a new crank if the crank snout is worn to the point that a new balancer is a slip fit.
You do need to check because the most common failure of a stock unit is the outer ring slipping off the inner hub.
Peter
Old Nov 19, 2011 | 11:21 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Do not wait on this if yours has come lose. Serious damage will result so it needs to be fixed right away. The suggestions above cover it.
To Loose Harmonic Balancer
