Seal between engine/transmission needs replaced
Old Nov 23, 2011 | 11:22 AM
Venger's Avatar
Venger
Default Seal between engine/transmission needs replaced
Hello all -
Took my '02 C5 with manual tranny to Chevy dealer to day to look at burning oil smell after driving. They said I have two leaks, one on the oil pan and the other between the engine and transmission (this is the expensive one apparently). They want 12 hours of labor to replace that seal. Is there someone in the DFW area who might be able to do this in a reasonable amount of time/cost? I don't have $1800 right now to put toward such a repair...
Any advice appreciated.
UPDATE: rear main engine seal housing gasket is supposedly the culprit.
Old Nov 23, 2011 | 11:29 AM
lucky131969's Avatar
lucky131969
Originally Posted by Venger
Hello all -
Between the engine and trans? You do know the trans is not directly connected to the engine, right? ......it's in the rear of the car.
Old Nov 23, 2011 | 11:34 AM
Venger's Avatar
Venger
Transmission, transaxle - he said transmission, so I merely repeat it here. Some component they claim is a 12 hour seal replacement for. If you know what that might be, I'd love to know...
Old Nov 23, 2011 | 11:37 AM
dougbfresh's Avatar
dougbfresh
I would check the oil pressure sensor to see if it's leaking, it's at the back of the engine.
Old Nov 23, 2011 | 11:42 AM
Venger's Avatar
Venger
Appreciate the info - alas, this exceeds my automotive expertise, but I will put it in the knowledge bank to be sure when I invariably take it somewhere around here for a second opinion...
Old Nov 23, 2011 | 12:10 PM
lucky131969
Based on your limited automotive expertise/knowledge, I'm not sure what you will absorb from the replies within this thread. The only task I could imagine would take 12 hours, would be a rear main seal, located between the engine and bell housing. I suspect they are guessing, as to the origin of the leak. As already suggested, it could be dripping down from above.
Old Nov 23, 2011 | 12:43 PM
MG RED 99's Avatar
MG RED 99
If your looking for a second opinion on a location to have the work performed, try posting a thread in the regions section for your area and get some recommendations for a local shop that does good work. A chevy dealership is almost certainly going to be the highest cost option. I'm sure there are some local tuners/repair shops near plano texas.
Old Nov 23, 2011 | 01:08 PM
Jet Moto's Avatar
Jet Moto
True street motorsports in mckinney should be able to do it for a good price
Old Nov 23, 2011 | 03:21 PM
Venger's Avatar
Venger
This is exactly what they said it was - I picked up the car and that's what the invoice said - rear main seal housing gasket. But you suspect that may not be it after all if I read your meaning correctly...
Did just that, thanks.
Appreciate the info, thanks!
Old Nov 23, 2011 | 03:30 PM
lucky131969
Impossible to make that assessment sight unseen. Oil can migrate down from other sources, and run between the seam....where the engine and bell housing meet. With out careful inspection, one might think it's a rear main seal leak. Choose your shop wisely.
Good luck.
Old Nov 23, 2011 | 04:40 PM
CordMcNally's Avatar
CordMcNally
This was the problem with mine when I noticed a leak. You can squeeze your hand to the back of the engine and rub around it. You'll know if it's leaking. Rear main seal leaks are much less common than other potential causes of oil leaks.
Old Nov 23, 2011 | 10:13 PM
rmata's Avatar
rmata
If I were you (assuming the leak isn't too bad) I would wait until it's time for a clutch. Since you won't be doing the work yourself, wait until that time comes and then pay the extra difference for them to replace your rear main seal while they are in there. It'll take an extra 10 minutes ontop of the clutch job. Otherwise, that's a lot of labor to pay to remove the drivetrain when all you need is a $20 seal replaced.
Old Nov 23, 2011 | 10:33 PM
csc67's Avatar
csc67
Check out this thread I created:
http://forums.corvetteforum.com/c5-t...-pictures.html
Old Nov 23, 2011 | 11:19 PM
dmarkshark's Avatar
dmarkshark
If I were you,I would take it to Corvette World over in Carrollton, off of 35 and get a second opinion.
Old Nov 23, 2011 | 11:33 PM
rebelheart's Avatar
rebelheart
Old Nov 24, 2011 | 12:13 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
You need a good mechanic cause,, the STEALERSHIP is trying to worst case scenario you for the wallet empty tactic! There VERY good at it!!
My guess would be a small leak from something minor and easily replaceable.
In this picture you can see the oil pressure sensor which commonly leaks, runs down the block and produces all the symptoms your having.
You can clean up the oil and see if you can trace where the origination trail comes from.
I seriously seriously doubt the oil pan seal or rear main seal are the issue. The oil pan gasket failure is almost unheard of. Most likely just needs to be snugged up to the proper torque spec.
BC
Old Nov 24, 2011 | 10:12 PM
Paul 75 L82's Avatar
Paul 75 L82
Take it to a Corvette shop.
To Seal between engine/transmission needs replaced
Old Nov 26, 2011 | 03:40 PM
Venger's Avatar
Venger
Thanks for all the info buys - Bill, or anyone - in the pic, which part is the pressure sensor? Is it the piece with the orange top and large rust covered bolt housing? Anyone wanna MSPaint a line on that pic? Lots of doohickeys there...
Thanks again for all the advice folks, appreciate the community here...
Old Nov 26, 2011 | 03:47 PM
lucky131969
http://forums.corvetteforum.com/1548974494-post2.html
Old Nov 26, 2011 | 03:52 PM
dmarkshark's Avatar
dmarkshark
Yes, its the copper colored piece.But its hard to see as it is tucked in the back of the engine area. Bill's pic has the manifold removed so its easy to see.
