MT0911's Build Thread
Especially when you have a huge support forum like this - I don't see why not!
thanks again for documenting your experience, both the good and bad.
I will say... that the tunnel plate was a killer!
Personally I use CDI Torque wrenches. They are a division company from Snap-On (and everyone knows how good the rep of Snap-On is). The quality is amazing and the prices are great and I can say CDI lives up to the name of being a branch under Snap-On. So if you are looking to buy definitely give them a look:
http://www.cditorque.com/
No problem about documenting and taking pictures. I think it's cool to look back on. And like I said man, I still have a lot more pictures to come along with a nice start up video! I'll be sure to post sometime soon (don't have my camera with me today).
It's funny because the very next day I borrowed a corded drill from a friend to drill some small 5/16 holes into the lifter trays to help avoid oil accumulation and I wondered why I didn't borrow it sooner lol. But hey even with hand tools I'm pleased that it only took me 4 days from start to completion and that was taking my time to do things right.
Alright guys here are the last of the pics like I promised! The "start-up/drive video" I will post this weekend. I'm still trying to work out that electrical issue that I talked about earlier but I should have it all wrapped up this weekend (I hope).
First, here's a shot of the Comp Cams Trunion mod
Here's my little 40 dollar press from Harbor Freight (worked perfectly)
Knocked out each trunion (man, those needles get everywhere! lol)
Here's a naked shot
Here's a shot of the action:
Got them all pressed like so
Here is a complete box of all of them
Here's a shot of the snap ring going on
I would say it took me about 30 mins to finish up all the Trunions, it's definitely a worthwhile mod
Alright, now to the next step:
Drilled some small 5/16 holes into my lifter trays.
Got the lifters and trays in and bolted up. And I laid my new head gasket right on top of the dowels to get ready to install my new Heads
Got the new heads on
Installed all the pushrods, rocker arms, and pedestal. Then I bolted everything down.
Got my new Ported Intake Manifold on
Here's a close up of my new injectors
Got the valve covers on and bolted up the new longtubes
Here's a shot from under. Looks beautiful in person
Got all the other PITA parts back on the car and just waiting for the finishing touches!
Finally got everything put back together. New Ported Throttle Body and Blackwing on the car!
Finally finished with the motor! Next up will be the suspension. Not too sure when I'll get to that but hey - the biggest part is finished!
I'll post a video of the start this weekend and hopefully my camera will do it some justice!
Thanks guys!
Well as I noted earlier, I'm running into those two DTC's:
Charge System Fault
P1637 - Generator L-Terminal Circuit
P1638 - Generator F-Terminal Circuit
I checked, cleaned, and tightened the connections to the Battery, Alternator, PCM, and the ground G104 near the battery. I started the car and measured the BATT terminal (red wire on back of the Alternator) to Ground and it's putting out a really low voltage IIRC around 1.47. I also measured the Positive Battery terminal to the BATT terminal on the Alternator and I'm getting around -10.4 so I see my voltage loss.
I have not yet checked or cleaned the starter connections or ground G106 - didn't have time today as I believe it will be a PITA since it is caged behind the passenger side longtubes lol. BUT I plan to attack it tomorrow and start her up again and see what I get. Hopefully that will solve my issue, we'll have to wait and see.
This is the schematic that I am working with. It's pretty straight forward so hopefully I can have the issue resolved by this weekend (knock on wood).
Well, just wanted to give an update on that situation. Thanks for watching and supporting guys!
If you ever are changing your lifters/trays out, drilling holes could prove to be helpful down the road. Truth is, it really benefits you if you stay in high RPM's for an extended period of time (tracking, multiple WOT pulls, etc) but it's good practice. Not absolutely needed and you'd be fine without drilling but it's sort of like a preventive solution.
As they said on Tech, the trays are at the top of the head and sitting at a 45° angle. I can't imagine they'd get more than a few teaspoons of oil before they started to spill over. And if I was racing, I'd put extra oil in the crankcase anyhow.
Cam -> Lifters -> Lifter Trays -> Push Rods -> Rocker Arms
Naturally the trays will accumulate oil due to the placement. You can see them clearly in this picture I posted:
It would definitely be more than a few teaspoons but it also depends on oil pressure. Unfortunately - there hasn't been incredibly testing on the "drilling holes" theory but structurally it should not affect the physical well being of the tray; it can only provide better recirculation of the oil if need be. The drilling requires no effort and takes about 2 minutes total. I wouldn't say it's absolutely needed since plenty of guys run without drilling and are completely fine but again it's more of a safety precaution just in case.
Just in case what? What are you expecting, that thousands of other C5 owners(with more extensive modifications) are seemingly unconcerned about?
You can only hope
I've read many publications suggesting drilling of the lifter trays. To my knowledge, nobody has provided any concrete information that this helps, or hurts, the engine in any way. I personally haven't done it.. and I don't plan to do it.. but I'm not going to insinuate to others they are idiots because they take the advice of many more credible people than someone hiding behind a forum name and avatar.
In any event, let's not derail this guy's build thread any longer. The anti-drillers already made their point... let it go.
