coolant leak???
Old Nov 26, 2011 | 02:19 PM
c5vettepoison's Avatar
c5vettepoison
4th Gear
Default coolant leak???
ok i bought the car in august and i love it. the previous owner guaranteed me there were no leaks. he said the car was in perfect condition. well im geting ready for winter so i bought a tarp and put it under the car. this weekend i decided to take it for a ride. i forgot my wallet in the garage so i went back in only to find coolant on the tarp. i put the vette back in and the next morning went out to check on it. the leaked coolant seems to be directly under the main drive pulley. is there any know problems with c5 corvettes leaking coolant. can you guys give me any tip on trying to find the source of the leak? i wanted to upload pictures but my computer hates me and wont let me.
Old Nov 26, 2011 | 02:34 PM
BRKLYN's Avatar
BRKLYN
Water pump? My .02
Old Nov 26, 2011 | 02:49 PM
c5vettepoison
4th Gear
maybe how do i check that?
Old Nov 26, 2011 | 03:13 PM
lucky131969's Avatar
lucky131969
Are your mechanical skills better than your computer skills?
Joking aside.........even if you do find the leak, can you perform the needed repairs yourself, or will it go to a shop?
Old Nov 26, 2011 | 03:17 PM
dougbfresh's Avatar
dougbfresh
You get UNDER THE CAR and see if you get coolant in your eye when your under the water pump!
Old Nov 26, 2011 | 03:29 PM
Vettmann17's Avatar
Vettmann17
Originally Posted by BRKLYN
Water pump? My .02
Most likely. Had to replace my WP at 70K for the same problem. Before you dive into changing out the pump get under it and make sure where the leak is coming from. Good luck bro!
Old Nov 26, 2011 | 05:42 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Its a high degree of probability that its the water pump as mentioned already. The only way to find out is to get under there and look closely.
Old Nov 26, 2011 | 07:18 PM
Cybermind's Avatar
Cybermind
As the others have mentioned, I'd bet it's the water pump. Replacing it is pretty straight forward as long as you've done that sort of thing before. The pump itself is not very expensive. A good aftermarket version is even less.
To coolant leak???
