chipped zr1 spillter
Old Nov 27, 2011 | 02:36 AM
Mattraffai's Avatar
Mattraffai
Default chipped zr1 spillter
ok i got home today and noticed that a small part of my cf zr1 splitter was chipped but not damaged. just the clear coat part was damaged and not the actual carbon fiber is there a repair kit or to fix this?
Old Nov 27, 2011 | 02:46 AM
Mattraffai's Avatar
Mattraffai
here is the pic in my profile pic.
is there another way to upload the pic?
Old Nov 27, 2011 | 07:01 AM
AU N EGL's Avatar
AU N EGL
Unfortunate that is normal
Expect lots of chips and scratches on splitters, side skirts and rocker panels
For extra photos need to start a photo account with something like Pisca or Photobucket
Old Nov 27, 2011 | 11:57 AM
dgoetz's Avatar
dgoetz
Repaired this one twice so far. This last time was from an off track excursion. second pic is finished just waiting for finish paint. This how it looks now.
This is why I chose fiberglass!! the cost to repair with me doing all the work was about $60.00 which was enough to cover two repairs.
Old Nov 27, 2011 | 12:43 PM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
Depending on the size of the area, the repair guys in our shop have used "3M™ Scotch-Weld™ Epoxy Adhesive DP100, DP100 Plus, DP100NS and DP100FR" for small cracks and ding fill in followed by various grits course to less course of wet sanding to a final buffing. If cracked too bad they are replaced with new.
Old Nov 27, 2011 | 03:30 PM
TrueBlueCoupe's Avatar
TrueBlueCoupe
Based on your picture I would get some Duplicolor Clearcoat Touchup at Advance. Layer over the chip to raise the area to the rest of the clear, then sand starting with 1000 grit wet dry and work to 3000 grit. Lightly buff with some zaino scratch remover and you should be good to go.
Old Nov 27, 2011 | 05:07 PM
dougbfresh's Avatar
dougbfresh
That's why these spiltter are a PIA, especially on lowered cars. Waste of time and $$$ if you drive the car much, you will eventually nail something with it and destroy/mangle it. I remember the later model C3's with the factory front spoilers-you would almost never see one intact-glad they designed the folding one finally.
To chipped zr1 spillter
