Coolent Temps into 210+
Old Nov 28, 2011 | 08:41 AM
zohhhsix's Avatar
zohhhsix
Default Coolant Temps into 210+
I was driving around town yetesterday in 60 degree day and my coolant temp all of a sudden went into 210+. It never goes over 190. What shoud I look for? Thanks
Old Nov 28, 2011 | 02:07 PM
tlove32's Avatar
tlove32
Did the fans come on?
Old Nov 28, 2011 | 02:08 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
plastic bag stuck up in front of the radiator
Old Nov 28, 2011 | 02:34 PM
billla's Avatar
billla
St. Jude Donor '14
Yep, look for something that got sucked up.
Old Nov 28, 2011 | 04:54 PM
Paul Wood's Avatar
Paul Wood
I would say relax and have a quick look for something in the radiator. 210 is nothing to get worried about. Mine does that and goes right back to 190. Was your A/C on?
Old Nov 28, 2011 | 09:19 PM
spdislife's Avatar
spdislife
Old Nov 29, 2011 | 07:35 AM
AU N EGL's Avatar
AU N EGL
Yup Clean the radiator out with an air hose at least once a year.
So much dirt, grass, Mikky Ds bags and dead Smart Cars get sucked up there
Old Nov 29, 2011 | 07:45 AM
runner140*'s Avatar
runner140*
Several years ago, my C-4 (1996) sucked up a t-shirt and the temps jumped 20-30 degree's for a couple of days.
Old Nov 29, 2011 | 08:12 AM
zohhhsix's Avatar
zohhhsix
Thanks Guys!! I will check for all that this weekend.
Old Nov 29, 2011 | 10:50 AM
Chicago1's Avatar
Chicago1
Your temp is fine.The low speed cooling fan is commanded on when the coolant temperature reaches 108°C (226°F). It is turned off if the coolant temperature lowers to 104°C (219°F). The high speed cooling fan is commanded on when the coolant temperature reaches 113°C (235°F). It is turned off if the coolant temperature lowers to 108°C (226°F). When the A/C is on and the coolant temperature reaches 85°C (185°F), the low speed cooling fan will be turned on at vehicle speeds less than 56 kPh (35 mph).
This is right from the tech manual.
Also if you have to burp the system use this technique.Here is the thread about burping the system from the heads. IMO the best and only way to do it. You may still have air in the system you can also put your new and old thermostat in a pot of boiling water and you can see it open to insure they work.
http://forums.corvetteforum.com/c5-t...erheating.html
Old Dec 23, 2011 | 08:50 AM
zohhhsix's Avatar
zohhhsix
I driving to work this morning in 50 degree weather and my temps got upto 220 within 20 min of driving and as I was parking my car at work it shot upto 250 and started coming out of the bottle with smoke. I think its my thermostat not working ....what you all think? Any help would be appreciated.
Umar
To Coolent Temps into 210+
