injectors ?
Old Nov 30, 2011 | 07:44 PM
geogolf's Avatar
geogolf
Default injectors ?
what would be a good replacement for the stock injs. in a 1999 corvette ls1 thanks in advance for your help geo.
Old Nov 30, 2011 | 09:49 PM
dougbfresh's Avatar
dougbfresh
If your not making any mods, the original ones.
Old Dec 2, 2011 | 08:37 AM
geogolf's Avatar
geogolf
Default injs.
thanks for the reply, but was wanting to know more about aftermarket would bosch 30 lbs be a good replacement I had good luck with bocsh in my 90 geo.
Old Dec 2, 2011 | 08:39 AM
geogolf's Avatar
geogolf
Default injs
ttt
Old Dec 2, 2011 | 09:28 AM
Tampa Tuning's Avatar
0Tampa Tuning
Former Vendor
St. Jude Donor '12
Default Corvette Camaro performance tuner in Tampa
If you change out injectors and go larger than stock, you'll need to have your injector table rescaled. So if you do that (and you dont need to if you dont have modification or plan on modifications) budget for a tune.
www.TampaTuning.com
Old Dec 2, 2011 | 10:15 AM
geogolf's Avatar
geogolf
Default injs.
thanks for the reply any idea what the stock injs. are 1999 350 ls1
Old Dec 2, 2011 | 10:45 AM
Vicarious.'s Avatar
Vicarious.
stock '99 is 26lbs @ 58 psi.
those bosch 30 injectors are actually 35-36lbs @ 58 psi for an LS1. Are you trying to convert to E85 or something like that?
Old Dec 2, 2011 | 11:29 AM
geogolf's Avatar
geogolf
Default injs
iron no, when I had my 90 I bought new injs. from fic and they were bosch the stock multecs on my 90 were junk maybe ls1 injs. are a better breed, was just trying to find the right bosch inj for my 99 thanks for any light you can shed haven"t had my 99 very long
Old Dec 2, 2011 | 01:43 PM
Vicarious.'s Avatar
Vicarious.
Fuel injection has improved greatly since 1990. Your '99 comes from the factory with EV6 style bosch injectors. No reason to upgrade
Old Dec 3, 2011 | 08:47 AM
baxsom's Avatar
baxsom
your injectors will support more hp than your engine is making now. unless you want to change the cam and heads and get a tune. leave it alone.
To injectors ?
