Shifter box, MGW says replace
Old 12-01-2011, 11:38 AM
1powdercoater
1powdercoater's Avatar
Default Shifter box, MGW says replace
Hello,
I am planning on installing a MGW shifter in my 2002 Z06. MGW suggests I replace the shifter box also. They state that if the car is 3-4 years old and has more then 25K miles to replace it when I do the shifter. My car has 31K.
I dont have a problem with doing that although I prefer not to spend money I don't need to. I am posting this because out of all the shifter posts I haven't really read any mention of this.
Old 12-01-2011, 12:07 PM
Gray Ghost GS
"AlohaC5" Senior Member
Support Corvetteforum!
Gray Ghost GS's Avatar
How much does the 'shifter box' cost from Gene Culley? I've been using the MGW shifter in my C5 for years now - it's awesome, and simply the best! I use the MGW shifter in my Mustang GT too. Exceptional quality.
Old 12-01-2011, 12:11 PM
lucky131969
lucky131969's Avatar
Originally Posted by AlohaC5
How much does the 'shifter box' cost from Gene Culley? .
Unless something has changed, I have never seen the box available separately.
Old 12-01-2011, 12:13 PM
Gray Ghost GS
I would install the MGW shifter with the parts provided and not worry about purchasing any new GM parts - just as I did.
Old 12-01-2011, 12:15 PM
r.hillenbrand
******RETIRED ARMY******
r.hillenbrand's Avatar
St. Jude Donor '12
was told same thing from MGW but just changed the shifter and it works great.
Old 12-01-2011, 12:29 PM
1powdercoater
Default shift box
Thats what I'm going to do then also. Napa couldn't find it listed for me and the one dealer I called said you had to buy it with the stock shifter as an assembly for $399.00.
MGW says they will have more built in a couple weeks.
Old 12-01-2011, 12:53 PM
Bill Curlee
Bill Curlee's Avatar
Received 2,180 Likes on 1,583 Posts
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Thats a bunch of BS!!! The ONLY reason that you would have to replace the SHIFT BOX would be failure of the RUBBER BUSHINGS that mount the box to the TORQUE TUBE OR if you have a defective shift ball bushing on the bottom of the shifter!
YOUR ZO6 has SOLID ALUMINUM BUSHINGS!!!!!!!!!! They will last a LIFE TIME!
KIRBAN SHIFTER on a ZO6 Shift box:
Stock ZO6 Box with aluminum bushing:
Stock vs KIRBAN with the shifter ball bushing
Unless your stock NON ZO6 rubber mounting bushings are completly SHOT, theres nothing wrong with your stock box.
You can NOT order new OEM bushings rubber or aluminum or the shifter ball bushing separtely. So the only way to get new bushings would be to order a new box (it comes with bushings) or make your own. Some aftermarket shifters come with new nylon bushings like B&M.
Old 12-01-2011, 01:00 PM
hotwheels57
hotwheels57's Avatar
One of the forum vendors sells reproduction rubber grommets now. The price is $21/pair...
Old 12-01-2011, 01:08 PM
tlove32
tlove32's Avatar
Just install the shifter - no need to replace the box
Old 12-01-2011, 06:34 PM
0MGW George
Former Vendor
MGW George's Avatar
St. Jude Donor '08-'11
with all due respect i am not giving my customers a line of BS!!! i dont make a dime on these things they are only sold by gm or gm parts outlets.
watch the video on my site that talks about the box swap and you will see the REASON i suggest it. i have personally installed probably 200 shifters in corvettes over the years and this is MY personal experience. these boxes do NOT last forever and i am NOT talking about only the outer bushings. i am talking about the seals in the rod itself that cause the rough shifting ,
also , since this customer has a z06 he will benefit from less vibration when installing our or ANY other short shifter that does not have the rubbery gooey shifter installed on it . even GM has done away with the z06 solid mount box in all z06 and zr1 vettes since 2009
obviously cars will vary greatly depending on climate they are in. how hard they are driven ie heat generated from racing etc, age and mileage. the best thing to do is to take off your console and inspect it and make an educated decision on it but frankly alot of people HATE removing the console so i just figure its best that if you have that many miles and years on it just get it for the peace of mind
and these boxes do NOT cost 399!!! gm parts house or parts taxui sell the whole unit for 110-140 tops. hell even from the dealer it should be only 180-200
george
sam-garcia (06-10-2023)
Old 12-04-2011, 06:20 PM
383's Avatar
george
Do you sell the replacement transmission linkage sphere separate? I ask because I got an offer on a used MGW and the seller says Ill need to reuse my old nylon cup and I just want to do it right the first time and not have to dig back in later.
Chris
Old 12-04-2011, 06:23 PM
Gray Ghost GS
George,
Thank you for designing and producing a QUALITY shifter - a real reliable and flawless performance product for our cars!
I have your shifter in my Corvette C5 and Mustang GT - both outstanding "must have" items.
I've tried others and there is NO comparison. Keep up the good work!
Mike
Old 12-04-2011, 07:54 PM
Bob Chapman
Bob Chapman's Avatar
I second Mike's comment George. When I got your shifter I thought that it is so nicely finished and engineered that I didn't want to put the shifter boot back on - and it works as good as it looks. Keep up the exceptional work.
Bob Chapman
Old 12-05-2011, 12:05 PM
hotwheels57
Chris
I thought the MGW shifter eliminated the plastic cup in its design? (It uses a larger "ball" at the end)
Old 05-07-2016, 12:50 AM
prmacho
prmacho's Avatar
george
Can someone direct me where I can find video or write up on removing factory shifter box? I have removed the three bolts two on the bushing and one on that hold the rod and I am lost from here on out since the box don't budge. Any help would be greatly appreciated
Old 05-07-2016, 07:00 PM
73Corvette
73Corvette's Avatar
You may just need to take a hammer and lightly tap on the shifter box, it is probably just stuck...don't go crazy and break something just tap around the edges and try to get it free... should come right out.
To Shifter box, MGW says replace
Quick Reply: Shifter box, MGW says replace
