abs/traction control module
Old Dec 1, 2011 | 09:52 PM
WV_VETTE's Avatar
WV_VETTE
Default abs/traction control module
I have a 1999 FRC and the traction control and abs lights have stayed on since I bought the car. The car does have c6 z06 style wheels with no tire sensors, could this cause the lights to be on? If not whats the best route to have the module repaired if possible, or buy another one? Either way does anybody know the average price for either or both fixes. Thanks
Old Dec 1, 2011 | 10:00 PM
lucky131969's Avatar
lucky131969
So you have already troubleshot the system? Know what the codes are, etc?
Old Dec 2, 2011 | 08:17 AM
WV_VETTE's Avatar
WV_VETTE
Yes, I have 3 codes
TCS no comm
PCM p1571
SDM u1040
Old Dec 2, 2011 | 01:14 PM
dougbfresh's Avatar
dougbfresh
The NO COMM is your killer, check the connection to the EBCM (unplug, replug the connector)
Old Dec 2, 2011 | 01:35 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
1st--a tire height change other than stock requirs a tune adjustment in your ECM to make the ABS work correctly--Also you MUST keep the "split" between the front and rear heights close to 1" as possible with the rears being taller--This is not tunable and may cause the ABS not to function or throw codes
The major cause of ABS/TC lights are fouled swheel speed sensor pigtails at each wheel-either weather/dirt fould or even broken wires--check all 4---
Old Dec 2, 2011 | 01:40 PM
lucky131969
True, but that does not account for why the EBCM is not communicating on the class 2.
To the OP, have you check for 12 volts and ground at the EBCM connector?
Old Dec 2, 2011 | 03:02 PM
WV_VETTE's Avatar
WV_VETTE
No, I haven't checked the 12 volts and ground at the ebcm.
Old Dec 2, 2011 | 06:02 PM
WV_VETTE's Avatar
WV_VETTE
Where is the ebcm located?
Old Dec 2, 2011 | 07:07 PM
dougbfresh's Avatar
dougbfresh
Depends on the year, the early cars had it all the way in the back of the car about the rearend, the later ones were right behind the radiator.
Old Dec 2, 2011 | 07:09 PM
WV_VETTE's Avatar
WV_VETTE
It's a 1999 FRC
Old Dec 2, 2011 | 07:14 PM
lucky131969
It's a 1999 FRC
1/2 year 98 and up are located in the front. Not trying to offend here, but considering you do not know where the ABS is located......do you have a meter, and are you capable of troubleshooting, if schematics are provided?
Old Dec 2, 2011 | 07:29 PM
WV_VETTE's Avatar
WV_VETTE
Yes, I work on tv's for a living. I'm just not real familiar with where the ebcm is located sorry.
Old Dec 2, 2011 | 07:38 PM
lucky131969
Cool. Here you go.
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Old Dec 2, 2011 | 09:18 PM
dougbfresh's Avatar
dougbfresh
WOW, someone still does that? Thought they just trashed broken TV's anymore.
Old Dec 2, 2011 | 09:34 PM
WV_VETTE's Avatar
WV_VETTE
Thanks for the schematics. Yeah, surprisingly enough some people still do have them repaired. But then again there are a lot of people that just buy cheap tv's and throw them away and get new ones when they break.
Old Dec 4, 2011 | 04:33 PM
WV_VETTE's Avatar
WV_VETTE
Seems to be working for the moment. I went to take the ebcm off today and there was a bunch of corrosion on the plug. Cleaned it off real good started the car and no more abs/active handling light. Thanks for the info guys
Old Dec 4, 2011 | 05:14 PM
dougbfresh's Avatar
dougbfresh
Nice when it's simple!!
Old Feb 14, 2014 | 02:23 PM
fal7's Avatar
fal7
2nd Gear
Originally Posted by lucky131969
Cool. Here you go.
Just found out fromchevy dealer no 1999 ABS modules available.
does anyone have insight where do get for a 1999 C5 with active handling ?
Old Feb 14, 2014 | 03:39 PM
coia96vette's Avatar
coia96vette
The early EBCMs have not been around for a while now. At least not new. They can not be fixed either. Only chance to find one is used and that's a crap shoot if it will work. Very expensive I have heard also. Glad I have an 04. Good luck.
To abs/traction control module
