In the case of the Corvette's IRS, you can't cure it the same way because of the design, so if I'm correct, the Pfadt bar is not needed if you have the brace connecting the diff to the trans. Like I said, I'm getting an ECS brace when I re-install my diff, which should be sufficient for a non-race car.
Im a bit confused on what your saying here, cause I cant tell if your talking about the effect of still eliminating wheel hop. I posted above you a clear statement that sums up everything:
Originally Posted by TriplBlk
To put this very clearly, ECS brace and Pfadt Trans brace serve two different functions:
ECS Brace: To strengthen the joint between the diff and Transmission.
Pfadt Brace: The Minimize/Eliminate Wheel hop and drivetrain movement under hard acceleration.
Wheel hop has been discussed many times on this, and other forums. In the case of straight axle cars, the culprit is axle windup, which ruins the angle of driveshaft to pinion. On these cars, the fix is to keep the axle housing from twisting by bracing it against the leaf springs, or adding welded links. On our Corvettes, it's been called "driveline shake", and will break things if you continue to have it. I believe it's caused by much the same phenomenon that's the cause in straight axle cars; namely axle windup. In the case of the Corvette's IRS, you can't cure it the same way because of the design, so if I'm correct, the Pfadt bar is not needed if you have the brace connecting the diff to the trans. Like I said, I'm getting an ECS brace when I re-install my diff, which should be sufficient for a non-race car. If ECS could chime in, regarding my theory, that'd be good, 'cause I'm just guessing.
I can see the Pfadt brace being more effective controlling the shake than the ECS brace. They both have there purpose & functioned as outlined.
The driveline is really supported on that small mount on the rear diff, so I think the driveline could start moving any direction once the shuttering begins, maybe even begin to oscillate. The Pfadt brace would prevent the side to side tipping as the width of the brace would spread that load. Then the up/down movement would be controlled the mount improvement & probably again by the width of the brace.
If you are willing to do some reading it would be worth going through this thread to better understand how the powertrain in the C5 and C6 works and why this brace may or may not be right for you.
BOTH Braces can be used together.
THIS.
This sums the situation up exactly. Our transmission brace is there to reduce power train shake and help our customers put more power effectively to the ground. The ECS brace is there to help eliminate part failure in extreme conditions. They are two different parts with two different functions that happen to share the same name and bolt to the same region of the car.
Both braces can be used together for extra effectiveness.
Well, to clarify; on C5s, the axle hop isn't actually that, it's driveline shake. If it is caused by axle windup, then bracing the diff/trans interface should eliminate the problem. I don't guarantee this, it's just a theory, and the manufacturer's opinion is great, but not exactly objective.
To bad Pumba drawings are gone, I would have like to seen those.
The other night when I was out looking at the C5 rear mount I could easily see what was being discussed. Driveline shake is probably a much better way to describe the problem rather than wheel hop.
As you modify you aggravate the condition & violence increases. Reacting torque, I liked that one.
So I'm in for Pfadt mount, once I have the drive line out & see what is wrong this time.....I will also look closely @ the coupler's.........I keep wondering if that was the tinkling sound I heard hmmmmm.
I did get a new vibration that starts at about 2200 under light acceleration. At wide open throttle its not there.
I have a Hinson poly transmission mount and have noticed the same phenomenon. Right around 2200 rpm at light throttle you start to feel and hear this audible vibe through the chassis that doesn't seem to be there at higher rpm (or anywhere in the rpm range when at WOT).
I've heard more than one person describe this with the pfadt mount too.
I noticed this when I changed the diff mount 3 years ago now. I forget what I changed since I posted that but it is gone now. Anyway it turned out not to be the mount causing the vibration. Also I guess it doesn't matter since Pfadt is out of business and the mounts are no longer produced.
My recently installed PFADT Trans Brace (last version) following the PFADT instruction to the letter and applying the recommended preload DO NOT CREATE any added vibration or generate any frequencies of any sort...
The only things that this PFADT part is doing...improving traction and stability plus predictability on off the corner throttle application of my monster torque engine through my monster tires.
I installed both the Pfadt trans brace and the ECS brace as part of my build. I have no wheel hop or vibration issues and the car feels rock solid/planted when accelerating/shifting...highly recommended for higher hp builds..
