Head Studs Question
Old Dec 3, 2011 | 01:55 PM
RonSSNova's Avatar
RonSSNova
Default Head Studs Question
Is it possible to install/remove the heads in the car with the studs in place? Or do you have to put the heads on then put the studs in?
If that's the case, I'll get the ARP bolts.
Thanks,
Ron
Old Dec 3, 2011 | 02:01 PM
vettenuts's Avatar
vettenuts
I was able to do it with all the studs in place. However, you may find it easier to leave a couple of key studs out until the heads are in place. I found this method easier when leaving the headers in place.
Old Dec 4, 2011 | 01:08 AM
BLOWNBLUEZ06's Avatar
BLOWNBLUEZ06
I have 6-bolt heads and am still able to remove/install heads with no trouble. Get the studs. You'll be glad you did. If you're going F/I or nitrous, get the 2000 series studs.
Old Dec 4, 2011 | 01:18 AM
RonSSNova's Avatar
RonSSNova
Thanks guys. The build will be NA.
Hinson has a good sale on ARP, so off I go.
Ron
Old Dec 4, 2011 | 06:40 AM
vettenuts's Avatar
vettenuts
One thing you do have to be careful of is to set the head correctly onto the studs. If you contact the studs with the bottom of the head and then move it (drag it) you can scratch the sealing surface of the head. Hope this makes sense.
Old Dec 4, 2011 | 07:41 AM
sean.b's Avatar
sean.b
about to do my heads/cam and this post answered a question i had too! thanks for the info
Old Dec 4, 2011 | 09:43 AM
RonSSNova's Avatar
RonSSNova
Perfect sense Marc.
Old Dec 4, 2011 | 10:51 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I went with the ARP STUDS and all I can say is WOW! They make head installation much easier and the quality of the system absolutely ROCKS. Ive had my heads off several times and I had ZERO stud issues. There were NO interference issues what so ever and the heads go on and off easily.
Just MAKE ABSOLUTELY SURE that the head bolt holes are clean and 100% DRY before you put the studs in and make sure that you install the washers that go under the nuts in the correct orientation !!!!!
BC
Old Dec 4, 2011 | 11:48 AM
BLOWNBLUEZ06
One other word of advice. If you have a 03 and later block, you'll be using the "equal length" studs, however positions 9&10 are .100" longer. Honestly I didn't notice until after the first time in installed them.
ok, I'll add a second recommendation. You need to know which block you have. Older will take the 234-4316 and the newer will take the 234-4317's
Old Dec 4, 2011 | 12:00 PM
CHIWS6's Avatar
CHIWS6
do u guys put the moly lube when u thread them into the block and when u put the nut the clamp down the head?
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Great INFO. Stuff that I didnt know! Thanks!! The pictures are on an 02 ZO6 Block.
Bill
Old Dec 4, 2011 | 06:55 PM
printmanjackson's Avatar
printmanjackson
St. Jude Donor '06-'07-'08-'09
studs go in block dry, lube nut threads and washer
Old Dec 4, 2011 | 09:05 PM
CHIWS6's Avatar
CHIWS6
i've read that gm says to torque it down the 75 but arp says to torque it down to 80? which 1 is it? these have to be torque down in 3 steps leading up the the torque # right?
Old Dec 4, 2011 | 09:18 PM
bracketshark's Avatar
bracketshark
Default Hey Bill
Hey Bill, is that 1/4" line thats running over the lifter valley, the take off of the rear coolant crossover line?
BC
Old Dec 4, 2011 | 09:28 PM
printmanjackson
when using ARP fasteners you need to use their specs.
Old Dec 4, 2011 | 09:59 PM
CHIWS6's Avatar
CHIWS6
Does the washer with the chamfer side go towards the head or facing up?
Old Dec 5, 2011 | 12:29 AM
printmanjackson
chamfer goes up to the nut
To Head Studs Question
