clutch chatter.
Old Dec 3, 2011 | 05:40 PM
rttmike's Avatar
rttmike
Default clutch chatter.
When letting the clutch out leaving a light, I get a chatter. It shakes the car until the clutch is all the way out. The clutch was replaced 10k miles ago with a spec. Stage 1. Any ideas?
Old Dec 3, 2011 | 05:42 PM
k0ts's Avatar
k0ts
Maybe oil on the clutch... Have you noticed a leak?
Old Dec 3, 2011 | 06:29 PM
rttmike's Avatar
rttmike
I have not seen any oil on the ground. I forgot to mention that the care also has a lightened flywheel.
Old Dec 4, 2011 | 05:29 PM
rttmike's Avatar
rttmike
Any other ideas? Maybe this is what spec clutches do?
Old Dec 4, 2011 | 06:02 PM
Lothar34's Avatar
Lothar34
10k miles is enough time for bolts to work loose if somebody didn't use loc-tite. I would visually inspect it.
Old Dec 5, 2011 | 08:24 AM
StatmanRN's Avatar
StatmanRN
I have a Spec II clutch and it does the same thing since install. People said it would get better but 15k later it hasnt. Grips fine though. I have had other HP clutches that chattered in the past on other cars. Decided Ill live with it until the engine comes out. The clutch change is a bitch.
Old Dec 5, 2011 | 01:41 PM
Lothar34's Avatar
Lothar34
When I read the OP I thought you were saying it just started to chatter. Has it been doing this the entire time it was installed?
Old Dec 5, 2011 | 02:25 PM
rttmike's Avatar
rttmike
I really can't tell you. I just bought the car and it has done this since I have owned it.
To clutch chatter.
