Gremlins
Old Dec 4, 2011 | 05:56 PM
DownByLaw's Avatar
DownByLaw
Default Gremlins
Howdy all,
Well, trying to get one of my last rides for the season in today, my '99 frc decided to go bonkers on me.
Basically, every warning lamp lit, every service warning came up, (service basically everything, reduced power, yada yada) radio shut off, windows stopped working.
Right before this occurred, my passenger window ceased working.
Upon parking in my drive, I opened the door, played with the accordion in the door, and the window worked and warnings ceased. However, upon closing the door, chaos reigned again.
So, my question, would a short in the door accordion cause all this mayhem? I haven't had the chance to pull codes. I guess if it is a short in the door causing this, a relatively simple fix?
So sad.
Thanks,
Patrick
Old Dec 4, 2011 | 06:00 PM
Lothar34's Avatar
Lothar34
Yes. Search for "clear door wire"
Old Dec 4, 2011 | 06:02 PM
lucky131969's Avatar
lucky131969
That is not the cause. Bill has tried to correct that many times in his posts.
Old Dec 4, 2011 | 06:40 PM
Lothar34's Avatar
Lothar34
Doubt is an unpleasant condition, but certainty is absurd.
Old Dec 4, 2011 | 06:43 PM
lucky131969
Sorry, that went over my head..
Old Dec 5, 2011 | 06:53 PM
DownByLaw's Avatar
DownByLaw
Well, I can't quite make out a consensus with the replies I've gotten so far, but I appreciate them anyway. I guess I'm going Occam's razor to start with, namely the door connection. I'll let you know how I make out.
Thanks,
Patrick
Old Dec 5, 2011 | 07:02 PM
lucky131969
Thanks,
Patrick
The link below shows what you want to inspect, and adds clarification to the "clear door wire".
http://forums.corvetteforum.com/1567486653-post586.html
Old Dec 6, 2011 | 09:25 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Lucky is on the money here. Long time common problem in the accordian tube.
Old Dec 10, 2011 | 06:07 PM
DownByLaw's Avatar
DownByLaw
Thanks all for the input. I believe I've fixed it. Took apart the accordion, used some deoxit on the plug contacts, spread them a little, snapped back together and taped with a little electrical tape for good measure. Fired up, no warnings and the window works. Need to get it on the road, but seems to have done the trick. Probably should do the same to the drivers side in the spring for good measure.
Thanks,
Patrick
To Gremlins
