C5 Random Stalling
Old Dec 6, 2011 | 11:05 AM
Armond111's Avatar
Armond111
Default C5 Random Stalling
I hope someone can help!! I recently purchased 1998 coupe, I've been having problems with it stalling randomly. I'll start the engine, shift it into gear, as I release my foot from the brake the engine stalls. It will start up with no problem and idle. I have pressed and released the brake while in park and it continues to run fine. I've shifted it into neutral and released the brake and it runs fine. I put it into gear and release the brake and it stalls. I have to restart the engine several times before it will run with out stalling. This doesn't happen all the time, it has occured when the engine is cold and has occured when its been running for a while. Ufortunately I've had to a mechanic and it hasn't occured while he's had it. I just replace the gas filter, has anyone experienced the same, this is very frustrating.
Old Dec 6, 2011 | 12:58 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
We'll need a list of mods to determine exactly what causing it--If bone stock that's one thing--but depending on your mods it could be in the tuning--
Old Dec 6, 2011 | 03:11 PM
Armond111's Avatar
Armond111
Thank you for the quick response. There is nothing listed on the DIC and when it was in the shop the mechanic said there were no codes showing up on the computer. Its frustrating because its so random, but when it does stall it takes 5 or 6 attempts before it runs.
Old Dec 6, 2011 | 03:14 PM
Armond111's Avatar
Armond111
The only mods that I know of are a K&N fresh air intake and mufflers.
Old Dec 6, 2011 | 03:19 PM
Armond111's Avatar
Armond111
Im such a Jacka**, I'm just reading the link sent to me about the DIC codes, I was thinking in another direction about this. I will and get back to you, thanks
Old Dec 6, 2011 | 04:39 PM
Armond111's Avatar
Armond111
Ok so here are the codes found in the DIC:
28-TCS C1226 H
C1255 H
AO-LDCM B2252 H
B2206 H
B2208 H
B2282 H
B2284 H
B2262 H
B2264 H
U1064 H
U1096 H
A1-RDCM B2237 H
B2239 H
B2253 H
B2203 H
B2205 H
B2283 H
B2285 H
B2263 H
B2265 H
U1064 H
U1096 H
A6-SCM B2192 H
B0851 H
BO-RFA C2120 H C
Old Dec 6, 2011 | 06:24 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
I agree completely...looks like a possible battery issue or battery connection issue at either the battery or solenoid.
Old Dec 6, 2011 | 07:40 PM
Armond111's Avatar
Armond111
Thank you, I will have that tested and let you know what I find. Whats your thoughts on the random stalling? It's very random and then after several restarts it runs fine
Old Dec 6, 2011 | 07:42 PM
lucky131969's Avatar
lucky131969
As suggested.....check the condition and security of the battery cables.
Old Dec 6, 2011 | 07:44 PM
Armond111's Avatar
Armond111
Will do, thank you
Old Dec 7, 2011 | 01:03 PM
tblu92's Avatar
tblu92
Very common on cold air intakes for owners or shops to over oil a K&N style filter----
The extra oil is sucked into your MAF and fouls it---The engine will do strange things as the fuel system is getting mis-informaton ---The oil burns onto the tiny MAF wires and does not work properly-----try cleaning the MAF with Brakeclean--clean the screen if it has one -Be careful not to touch the wires or screen----drive it apprx 50 miles for it to relearn the trims---
Old Dec 19, 2011 | 08:42 AM
Armond111's Avatar
Armond111
I want to thank you all for for your advice. I believe the random stalling has been corrected. I had the battery charged, had the ground connections checked, there was no corrosion and changed the fuel filter. One or all of them did the trick. Thank you again for all your help
To C5 Random Stalling
