I would definitely pull off the manifold covers and look for a broken spring. Your vibration symptoms are similar to what happened with my 2004 C5 just before a valve spring broke.
If that valve drops in the engine, it will destroy it - well worth checking.
Thanks for the visual I'm planning to pull the valve covers Saturday and it's nice to know what all to look for specifically.
Did you only have to replace the springs or is there an underlying cause for something like that happening?
From reading the forum, there was a bad run of valve springs (guessing here) that happened around 2002-2003. Somehow my 2004 car got one (maybe more) and it failed at 95,000 miles.
I just replaced the broken spring just to test if that would get rid of the P0300 DTC error. I'll replace the rest when a get a shipment in.
All I can say is the car has never run so well. I had changed the spark plugs, wires, cleaned the MAF and checked the fuel pressure. No improvement until that spring was swapped out.
It took $100 in special tools and some pretty sweaty minutes while I removed the keepers and then the spring. I had an air compressor running, putting air in the cylinder (100psi) to keep the valve from falling in the cylinder.
As a previous poster said, take it to someone that knows how to do it - if this makes you nervous.
I certainly hope you did not just replace ONE spring....
Regarding the compression test, don't we have an electronic throttle control? So should I remove the air bridge and manually hold the throttle body open or just leave it be and push the accelerator pedal down anyway?
Did the compression test on the foreward most 6 cylinders (friend had to leave) and they were all the same, I'd say about 160-170psi. It's not that easy to read accurately.
So I threw in some new plugs and I want to say it is a little better when getting on the gas but honestly it may just be that now I am willing to dip the throttle a little deeper without thinking I'm going to break something. But the searching it does when winding down past idle is now worse.
Even though I'm sick I could definitely smell something with the hood up, maybe an exhaust leak? I would have thought that would be audible though. Revving doesn't seem to be an issue when WOT with clutch in, but it does shoot fuel or some clear substance out the exhaust tips.
And one more question. When pulling the #8 plug I knocked off this little cap in the pic below, so I tightened it down all the way. There was another one (see second pic) which was a little loose so I tightened it down all the way too. What are these and if they are some sort of vent should I loosen them back up again? I don't know what else to blame the problem of overshooting idle on. I can't see why new plugs would make it WORSE.
That is the a/c line, so that cap should be on tight.
As for the smell - be a little careful. When my engine was misfiring (P0300), it was putting carbon monoxide. The garage door was open and the car was idling for a few minutes- and it set off a CO sensor with a high reading (110 one time). If it is over 50, you need to get out quickly. Note: carbon monoxide does not smell, but you can smell unburnt fuel (or whatever).
After the misfiring was fixed, the CO sensor does not read a trace.
Those caps are the covers for the A/C ports. Nothing to do with your problem
I'm going to replace the AC belt tensioner pulley this week (I think that is the wine glass sound I had mentioned) and then pull the intake and valve covers this weekend. I think I'll pick up a can of Seafoam to try to decarbonize the cylinders too. What else should I check for this weekend?
went to where you suggested, gear chatter.com and couldn't find the DTC codes that my '99 C5 are displaying to me: G0 IPC U1160H, B0 RFA U1255H, U1096H, U1064H, U1016H, C2100 HC. I'm hoping to get rid of most if not all these codes when I replace the plugs, wires, O2 sensors, but would still like to know what all these codes pertain to???
From: Norman Oklahoma - The Only State in the Union with no Blue Counties!
96, 64, 16 are all ground related. Check the G105 ground located under the block, driver's size! Bet it is loose!
To add to Silverbullet00's great advice, the C2100 is your left front tire pressure sensor
Having some friends in one of your local Corvette groups it worth its weight in gold at times like this. If you have access to someone with a C5, swap wheels and tires with them long enough to evaluate the vibration issue. This would allow you to rule out wheel and tires. You mentioned in your first post that pushing the clutch in didn't change the vibration much, correct? I agree that you may have an engine issue, but if you turned the engine off and you still had one of maybe more vibration sources, you need to start ruling the easy ones out.
I just spoke to a guy at my work with an 04 and a scissor lift and we are going to see what we can do after the hollidays.
But I plan to take the intake manifold and valve covers off this weekend to ensure there is nothing that would suggest I shouldn't continue driving it for now. Should I pick up some new gaskets at Autozone for when I put it all back together? If so what do I need?
