Clutch problem???
Old Dec 18, 2011 | 02:35 AM
Iwannagofast1999's Avatar
Iwannagofast1999
2nd Gear
Default Clutch problem???
Ok i installed a new slave cyl. in my vette about 5 months ago along with a new clutch and flywheel... Latley i have been noticing a strange noise at idle... The mystery noise stops when i press the clutch in and returns when i let off... its a loudish chattering noise... Any ideas at what this may be??? THanks for any help!
Old Dec 18, 2011 | 07:35 AM
k0ts's Avatar
k0ts
Does NOT sound good... Sounds like a bad throw out bearing but it should be nearly brand new...
Could flywheel bolts be rubbing?? I'm not sure if there's an inspection cover but I'd
get under there and take a look...
Old Dec 18, 2011 | 08:37 AM
Paul 75 L82's Avatar
Paul 75 L82
I would get it on a rack and see what you could hear then.
Old Dec 18, 2011 | 08:54 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Wondering if some of the bolts are backing out?
Old Dec 18, 2011 | 09:47 AM
Eric D's Avatar
Eric D
St. Jude Donor '09-'10-'11
Where did the new parts come from, what brand, and did you contact the supplier to see if maybe they had a bad batch?
Old Dec 18, 2011 | 09:56 AM
helga203's Avatar
helga203
Is it a twin clutch?? I have the MST Mcleod twin and sometimes i get a knocking sound from the disks from the rotation of the engine when i press the clutch in it goes away. It's normal it's not majorly loud but noticable.GL
Old Dec 18, 2011 | 10:44 AM
Eric D's Avatar
Eric D
Who convinced you that the "knocking sound" is normal?
Old Dec 19, 2011 | 02:07 AM
cdkcorvette7's Avatar
cdkcorvette7
Did you do the install yourself or did a shop do it? What parts did you put in?
To Clutch problem???
